Headers with GT40P heads
Discussion in 'Technical' started by maver88, Jun 24, 2011.
  1. maver88
    maver88 Nick Taurone
    Russellville, AR
    1972 Ford Maverick 2-door & 1996 Ford F150 4wd w/ 429ci/granny low 4spd
    I have a 302 that i planned on putting gt40p heads off a 98 explorer on it and then into my Maverick
    I heard that there is a header/spark plug clearance problem with these heads
    is anyone running them & what header are you using i was planning on buying the headman 88300s
  2. Earl Branham
    Lugoff, SC
    I think you can use the short "peanut" plugs and they will work. Headers may interfere with the shock towers, however. Good luck.
  3. maver88
    Russellville, AR
    you have a part number and maybe a brand name for these?
  4. Dave B
    I think it's been discussed a number of times. a search should find all the info you'll need.
  5. scooper77515
    http://mmb.maverick.to/showthread.php?t=18214&highlight=GT40P
    Check this out for the plug clearance issues.
    The plugs are Accel P526S shorty plugs. And then use 90 degree HEI type boots, and even then, you will burn the plug boots. I ended up with a header flange to use as a spacer, and then 3 layers of gaskets on both sides to get the header out away from the plugs a bit.
    I also made this [​IMG] to get under the headers and get the plugs out. Still had to lift the engine off the mounts, and remove the header to remove any of the spark plugs.
    I gave those P heads away and got a set of the non-P GT40 heads. No plug issue at all now.
  6. maver88
    Russellville, AR
    thanks for all the info
    i think i'm gonna use them anyway lol
    i may reget it later but that only other set i have needs alot of work and they are stock E7s
    the gt40p s i have are ready to install
  7. car-nut
    car-nut Glenn
    conn.
    I have the P heads on my engine and I bought the Ford Motorsports stainless headers. They are not cheap at $350, but their is no issues with spark plugs at all.
  8. bmcdaniel
    The Motorsport headers fit a Maverick?
  9. Dave B
    They will without shock towers....:rolleyes:
  10. bmcdaniel
    LOL, if I went through all of that I wouldn't be fooling around with P heads.
    When I ran P's I used old Blackjack headers, and Accel shorty plugs in the driver's side with the 90* terminal/boots that Scooper mentioned.
  11. chirt
    chirt Carlos Hirt
    Massachusetts
    Spark arms!
  12. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    i run mine with shorty plugs, and ceramic boot spark plug wires made by accell, i used to burn up wires very often, i've put over 500 miles on the set now without any issues?
  13. BamaV8MavMan
    BamaV8MavMan Member
    Attalla, AL
    1972 Ford Maverick 2 door V8
    Can anyone tell me what is the best long tube header to use with GT40P heads? I have stock shock towers that have been shaved back about 3" with stock motor mounts and a 91 Mustang GT roller motor. The clearance issue seems to be in the lower setting of the engine, I will need a block hugger header but, I know I will have to use accell shorty plugs and wire boots to keep from melting the wires. I just want to know from experience who makes the best header for this combo?
  14. maver88
    Russellville, AR
    Denso makes a short plug p# 5023
    I am running those plugs & and head man 88300 headers with a header spacer on the dr-side to clear the header with no boots or boot burning problems with regular Accel wires, but I had to clearance the header a bit to get it past the shock tower & steering box. I had to make a tool to get the spark plugs out, but I can do it with out removing the header or jacking up the engine, you do have to pull the valve cover though but that just makes it easier.
    I will take some pictures of this setup & my spark plug tool tonight and post them.
    I think someone on here was advertising some Crites headers that I thought also worked on a 302. They looked like they would clear GT40P heads good because the tubes went straight down then back, but their kinda pric-ie $350~ plus shipping, for much more than that u could just buy a different set of heads lol and save ur self the aggravation.
  15. scooper77515
    Here is the tool I made to get the plugs out.
    Before [​IMG]
    After[​IMG]
    I started with a deep 5/8" 3/8 drive spark plug socket, then cut it down and cut a window in it so it would slide over the plugs from the side. Also had to drill out the top so the plug body would extend out through it. This thing rides really low close to the plug base, and is tightened and loosened with a wrench.
