headers
Discussion in 'Technical' started by wolfheads, Apr 30, 2015.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    What type or brand of shorty headers will fit my 73 Maverick 302 w/ automatic on the collumn and power steering I've found some that will fit if I had a floor shift automatic, BUT I don't have that.
    Thanks
  2. Craig Selvey
    I think all the shortys that advertise for a Maverick out there will work. I know the Doug Thorley and the Hedman Shorties will work with the configuration you have. I am unaware of any others that will. Do a search.....tons of threads on the topic.
  3. olec4
    olec4 Member
    1972 Green Maverick
    did you find a solution? I have a 72, 302, c4 auto ,column shift, power steering, as well
  4. wolfheads
    wolfheads MadMav
    Florida
    Hedman shorty headers worked.
    dmboshkov likes this.
  5. HadaGrabberonce
    HadaGrabberonce Member
    Talcott WV
    1973 Maverick 302 C4 3.55 Tractionlok Granada disc brake conversion Small front bumper
    The Hedman shorties did not work so well for me. I have a 73,302,column shift and power steering. The pitman arm is the problem area. I had my exhaust shop install them along with a complete dual exhaust while I was on vacation. I explained to them the possible clearance problem with the pitman arm. When I picked the car up, I asked about the clearance and was told no problem. I was pretty happy with the looks and the sound of the Thrush turbos but I knew there was a problem when I tried to turn around in my normal spot (left hand turn). I have lost a noticeable part of my left steering because the pitman arm is hitting the exhaust pipe.
  6. HadaGrabberonce
    Talcott WV
    Has anyone tried the stainless shorties on Ebay?
  7. mojo
    I have the Hedman's, but I used optional 2 in. extensions. I installed my own headers and saw the 2 1/4" might hit the pitman. I do not seem to have an issue w/ left turning. I also have power steering.
  8. HadaGrabberonce
    Talcott WV
    He did use a short piece of 2" pipe into 2 1/4" but the arm hit right at the weld. I had to dimple it to get the full movement back on the pitman arm. I am wondering if the Chinese made shorties sold on Ebay would work better. The driver's side outlet appears to exit downward a little more than the Hedman.
  9. Krazy Comet
    Knowing the particular set to which you are referring would be helpful.
  10. HadaGrabberonce
    Talcott WV
    Yeah, I should have been more specific. The ones I am referring to are the Chinese made no-name T304 stainless ones. Several speed shops on Ebay list them as fitting a Maverick. Some of them appear similar to the Hedmans but the drivers side exits downward more than the Hedman. I know many people like the Doug Thorleys but they are a little pricey for me.
  11. mojo
    I would not feel comfortable w/ a set of those Chinese made units. Using comments on the Hedmans and Thorley's was what my decision was based on. I want something confirmed for my money and time spent. What if the off-shore units don't fit w/o issues? Who do you take return issues too? What is the quality of material and fitment?
    Sometime, cheaper is not always better -- Just cheaper. The Hedmans went on w/o issues, didn't have to raise the engine, they just slide right in. Ease of install, worth a few more bucks to me. JMO
    RMiller likes this.
  12. Bad1974maverick
    Bad1974maverick Member
    Columbus Ohio
    1974 Maverick Grabber
    What model of hedmans did you put on that did not cause you trouble or pitman arm problems? I have a new exhaust on my 74 302 P/S column shift and I'm getting ready to do head gaskets and want to do shorty headers!
    Let me know please.
  13. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    I have a set of the stainless ones sold on eBay. Was perhaps going to use them on my 57 F100 project, but I might just try them on my 71 comet. I can say they are very heavy and the welds look pretty nice. I’ll post some pics of them when I get a chance tomorrow.
  14. mojo
    I bought shorty Hedman 88408 -- I don't believe you will get a shorty set that will not interfer w/ pitman arm. Long tubes, drop bracket required -- pro's and con's either way. You may be better off w/ stock header if your not willing to make any changes.
  15. Bad1974maverick
    Columbus Ohio
    Do I need to mod the header before it goes on to clear the arm? there is a local exhaust shop that has classics come in from everywhere. is the turn ratio that noticeable?
