headlight flikering??
Discussion in 'Technical' started by togetic2002, Aug 26, 2007.
  1. togetic2002
    togetic2002 Member
    Reno NV
    72 sprint(major reconsruction),92 5.0 ho t-bird
    ive been reading the other posts and havent found any thing for myn
    my lights are flikering but all the time car on car off . switch makes noise for some reson:hmmm: like arcing
    an elecrical place tryed to but couldnt fix it . found out all they did is tape up some bare wiring no soader or nothing?:huh: i could of done better
  2. Mavaholic
    There are 2 self resetting circuit breakers built into your headlight switch. One controls the headlights themselves, the other controls all the other lights in the car. Either you have a short somewhere that is over loading a circuit, or the switch is bad. Another thing that can cause this, voice of experience, is you put too many lights in the circuit and it is just overloaded. :D
  3. BRUCE RANEY
    BRUCE RANEY Member
    o.p. kansas
    4 door 1976 ,52,000 mi
    Bruce Raney
    IT IS THE REGULATOR---15 DOLLARS
  4. BRUCE RANEY
    BRUCE RANEY Member
    o.p. kansas
    Gary
    You Need A New Regulator
  5. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    From the sounds of this,,like Mavaholic says,,,go with a new headlight switch. Any parts store should have it. If still flickering, look for extra lights an shorts. May want to pull headlight bulbs an "clean" or replace connectors.
  6. Earl Branham
    Lugoff, SC
    I had that problem a few weeks back. Turned out to be a loose wire on the alternator and a bad ground. Trace the wiring, and see what you find.
  7. togetic2002
    togetic2002 Member
    Reno NV
    i tryed the switch and regulater but its worse now it doesnt just dim it goes completly off and on at about 2 to 3 sec intervols and my tail lights dont work?
  8. Mavman72
    Sounds like you have a short thats tripping the circuit breakers on the head light switch or perhaps a bad ground.I would lean towards a short judging by the symptoms.
  9. bmcdaniel
    The horn is also powered through the light switch circuit breakers.
  10. just_got_a_72
    just_got_a_72 Member
    Redding Ca.
    72 grabber yellow.
    just a thought
    Bang on the dimmer switch a few times. I always check this.
    Missed the "taillights don't work" part.
    Do the basiic stuff. Replace the fuse. Clean the battery terminals. If your + battery cable has 2 wires (big and little) is there a buncha corrosion there??
    Ben
  11. togetic2002
    togetic2002 Member
    Reno NV
    na no corosion and new termanals just dubble ckecked and all is good .
    i put up another post asking if any 1 could tell me what color is what on the switch connections so i can bypass the bad wires and run new ones.
