Hello, has anybody used the Ron Francis HR-56 Headlight switch relief relay? The Relay connector will not plug into the dimmer switch. I got it because of the Brite Light Feature. Lighting both the high and low beam filaments at the same time. Thanks Tony
:HandshakeHello, just called Ron and he give me the dimmer switch P/N SD-02 and the connecter I will need. Just called summit they will be here second week in Dec. Thanks for the tip. Tony
