got in my 70 mav tonight and the head lights wouldn't come on ,tail lights works ,front parking lights work and dash and interior lights also working but both head lights aren't shining,has the switch went bad??
Check for power on yellow & red wire at dimmer switch, if there is none it's likely the headlight sw or maybe problem with that wire... If there is power, check the dimmer switch...
Guess I should of mentioned if high beam indicator lights, problem is in wiring to bulkhead connector or under hood...
