heat tolerances on a 200
Discussion in 'Technical' started by adam 72, Jul 8, 2013.
  1. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Hey,
    I have a 200 inline with a 180 degree thermostat. Here in NM the roads get pretty hot and im wondering around what temperature this thing should be shut off.
    Thanks
  2. Dave B
    Like not driving the car when it's hot out?
  3. Acornridgeman
    Wisconsin
    I'm not sure what you are asking ---- shut off?
    If it is a 180 degree thermostat, that is fine for desert heat. The factory used low temperature thermostats that were 184 degrees.
  4. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    mean when is it unsafe for the engine to run. I shut the car off when I see the temp red above 200 degrees. I try not to drive it when it's hot but it's my only car. I just don't want to push it too much. Once I hit the city I see the temp climb. Just wondering when too hot is
  5. Acornridgeman
    Wisconsin
    A normal engine will run around 210-220 all the time in summer. As long as you have a correctly operating cooling system with a good coolant mix, you should not fear driving it, even in the desert heat.
    Have you had trouble with overheating? (boiling over)
  6. Dave B
    My car might get to 190 in traffic, but very rarely any higher than that. So I have no real idea, but when you see steam shooting out from under the hood, at the car starts bucking...then it's too hot. I doubt there is a definite temperature anyone can give you.
  7. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    It has over heated a few times before. My last engine at least. I just was wondering if there is a ball park for "safe" (before boiling over).
  8. Acornridgeman
    Wisconsin
    A few basic things prevent boil over.
    A clean cooling system both inside the engine and inside the radiator.
    A radiator cap that holds proper pressure in the system.
    Proper mixture of coolant.
    Working thermostat and water pump.
    Correctly set fuel mixture and timing.
    If all of these things are as they should be, you should not be having a boil over even in the desert.
  9. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    alright cool. I'll double check also those things. Thanks
  10. Krazy Comet
    With a 50/50 antifreeze/water mix and a 13-16Lb pressure cap, boil over will not occur until past 250*F, which is the limit one should run a engine... Myself, I get antsy at anything more than 225-230* but again if it's necessary to run higher, there won't be a issue... Would be a good idea to use a 5/10W-40 oil if you anticipate regularly running over 200*F or more...
  11. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Well I don't want thinner oil since I have a bad ring on the #5
  12. Krazy Comet
    Then you're using something like 20W-50??? (which in hot climates is fine)
  13. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    No. Next oil change im putting that in. I think it's 10w-30 now
  14. Krazy Comet
    Any 0/5/10W-40 is thicker than 10W-30 when its hot which is when it counts... The first number indicates how thick the oil is when cold & even 0W or 5W is several times thicker cold than a hot 30, 40 or even 50W... All oil thins out when hot, the higher numbers just thin a little less...
    A ideal oil would maintain a constant viscosity from cold to hot, unfortunately there is no such thing...
  15. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    That's good info. I didn't know that about the ratings
