Heater A/C box
Discussion in 'General Maverick/Comet' started by texasjack, Feb 5, 2009.
  1. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Today I installed the heater A/C box in my 75. The problem I am having is connecting the box lines to the block. I was sent a box for a 77 and the lines are different lenghts and one will start but the other line will not start.
    I may pull the box and use the evaporator core from the 75 box.
    I thought the Mavs would be the same.
    Texasjack
  2. Craig Selvey
    Lines should be the same length.
  3. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Box
    Craig
    They ain't, the lower line is longer than the top one but the hole in the block is also deeper. I will probably pull the box out and install a new heater core and the evaporator form the 75.
    Texasjack
