Heater Blower Motor
Discussion in 'Technical' started by mtrhed, Feb 2, 2004.
  1. mtrhed
    mtrhed Member
    Braselton, Ga
    Grabbers
    Does the Heater/ AC Box have to be removed to access and replace the Fan Blower Motor. If yes, I presume this is major surgery like on the early Mustangs. Any suggestions or how to`s and what to beware of would be appreciated. (1971 Maverick - V8 with Air )
  2. igo1090
    igo1090 Member
    catonsville, md
    my son & i just replaced the heater core on a 1975 with a/c. we took the box out without the blower, but now that we have done it, it could all come out as one piece. its easier than the old mustangs because the bottom half of the dash uinbolts and comes out of the way. unbolt dash, remove air distribution box from bottom of box, disconnect cables and vac lines, take nuts off 3 bolts thru firewall, remove support brackets and ducts from blower, then pry box loose from firewall. after box is out then remove clips that hold 2 halves together (if replacing core). hope this helps.
  3. Mavaholic
    Hey igo, I see you are right up the street from me. Pretty cool, another Mav in the area.
  4. igo1090
    igo1090 Member
    catonsville, md
    picked it up on ebay last year for my son. has become the maverick from hell. have done many cars over the years, even built my own tube chassis car. have never had so many problems as with this thing. matches and a gallon of gas are sounding real good right now. oil leak in rear of engine, untraceable power drain when key off. you name it, its gone wrong.
  5. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    On the a/c cars the blower motor detaches from the heater/evaporator core box without taking out the box. It's located in the center of the car on the driver's side of the box. Take off the floor distribution vent, and take off the air distribution box above the motor (one going to the vents in the center dash also with hoses hooked to go to the side vents). Look up into the motor housing from the bottom opening where the floor dist was attached, and there is a nut holding it to the heater box. Take this nut off, and because the hole it was in is slotted, turn it either back or forward (can't remember which right now) and it will dislodge it from the other three slot clips that hold it on. Then unplug it and pull it out. It sounds confusing, but once you get in there, what I said will make much more sense. Good luck!
    -Corbin
    Gdnewby1126 likes this.
  6. mtrhed
    mtrhed Member
    Braselton, Ga
    Grabbers
    Corbin - Since the heater was working fine before the blower motor stopped, I`ll try your instructions for the fan motor only replacement - that could save lots of time and grief - thanks for the info.
  7. Craig Selvey
    Try checking the fuse first. Also check all wire connections to the blower motor.
  8. mtrhed
    mtrhed Member
    Braselton, Ga
    Grabbers
    fuse/wiring
    Yeah, I was hoping that it was the fuse but it checks OK and wiring appears good also - I guess I should check for 12 volts at the motor before I begin surgery . Either way it involves a lot of standing on your head and working upside down - but - gotta have heat.
  9. Corbin Johnson
    Here's a diagram that shows more of what I am talking about. Hope it helps - I know that I always get things done faster when I know what it looks like and how it's held together.
    -Corbin
  10. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    The first thing you should do is just take some jumper wires and hook upto a battery then to the blower if it works motor is not to blame. If that checks ok YOu have a power supply problem or a ground that needs fixed.
  11. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    not for nuthin... my 72 has a heater motor that needs a little "love tap" sometimes to get her going.
  12. New2Maverick
    New2Maverick The Newbie Sponge
    Oregon
    1974 Maverick 4 dr, v8 302
    Hey people,
    While we are on the subject of heater boxes and such, does anyone know where I could pick up one that is in decent condition? I have a 74 four door w/AC.
    By the way Corbin that pic that you posted do you have one for a 74 or do you think that it is nearly the same? From what I can see under my dash it looks very close.
  13. Corbin Johnson
    I think it's exactly the same. If not, almost exactly. :D
    -Corbin
  14. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    It's nearly the same.
    I love exploded views. Problem is, they never show all the crap you have to go through to get to that assembly!
  15. New2Maverick
    Oregon
    That is so true!!!!!
