Heater core (with A/C)
Discussion in 'Technical' started by benben, Sep 14, 2004.
  1. benben
    benben Member
    Europe, Estonia, Tallinn
    Mav`75, 302, 2d, A/T, A/C
    ...is leaking. Can I fix it or this is not a good idea. I do'nt wont do removal and installing of heater A/C housing twice :smash: . Or can I use the heater core from another model(car)?
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Remove the bottom of the dash.
    Disconnect all of your wires, vacuum lines etc.-label them.
    You have a few nuts that need to come off the firewall behind
    the engine. It is easier with the front passenger seat(s) out.
    The entire assembly will come out.
    You do have to discharge your A/C and remove those pressurized
    lines to do this properly.
    I bought my core from Advance Auto. I don't know the availability
    of parts in Estonia, but you can order them online. They should be
    less than $40/US. I don't know if they are interchangeable with other
    cars.
    Best of luck,
    Seth
  3. benben
    benben Member
    Tnks, Seth!
    I have the entire assembly in my trank allredy (y)
    the availability of parts in Estonia is ok, but the time is another question, aprx. one month and the car is sleeping true the winter with some other old US cars in garage. I'll tcheck this Advanced Auto.
  4. littleredtoy
    littleredtoy Seth
    '74 Comet GT
  5. 71gold
    if you still want to drive the car and do the repair later. you can take the two heater hoses off the block and run a short hose from one outlet to the other. that way you are bypassing the heater all together. it will not hurt anything to hook it up this way. you just want have a heater...frank...
  6. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Four words:
    Pain In The ASS . . .
  7. PaulS
    You can also try "Aluma-Seal" a powdered aluminum sealer that won't clog the core. There are a couple of others - "Bars-Leak" makes a powdered copper sealer that comes in a liquid base that has no Sodium Silicate in it and it is supposed to work well too.
    PaulS
  8. benben
    benben Member
    Tnks to all!
  9. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    my heater core went out in mine the other day......just by-passed it for the time being........T.L. is correct.........definite PITA!
  10. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    It's a pain, sure. I took off my lower dash for better access. I am able to do this without disconnecting the AC. Romove the brackets under the hood so you can pull the AC hoses through the firewall as much as possible, and split the heater box while still in the car. It can be done pretty easily. R-12, if you can find it in the states, is about $50 a pound. Good incentive not to discharge the AC, if you ask me....
  11. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The heater core is the same as a 69-70 Mustang with air.
  12. benben
    benben Member
    As the old saying tell :where the problem is major, there a help is near byOur forum member is helping me out :clap: .The heater core is fixed and tested under the pressure. He is fixed own '74 Pontiac LeMans radiator and heater core to. Tomorrow I put back the assambly.
    To Max power:The AC hoses are not so long and how do you think to open this heater box clipses from the firewall side, 6 pieces in wery difficult places. I release AC hoses from the pump and the oil reservuar therefore houses on this top are stronger then the evaporator cores side. And I do not disconnect all vacuum hoses.
  13. Max Power
    St. Paul, MN
    Reach around. I've done it a number of times, you can too. Of course, you can probably still get R-12 there for a reasonable price.
