heater hoses on 70 maverick
Discussion in 'Technical' started by pipman76, Jul 22, 2010.
  1. pipman76
    pipman76 Member
    alabama
    1972 mav
    im putting my mav together its a late 70 column switch car ,this car didnt have the heater hoses connected so i wanna hook it up to see if it works whcu hose goes where the hosees are stacked coming out of the fire wall i was thinking the top hose runs to the intake and the bottom hose to the water pump. Is this correct ???
  2. rthomas771
  3. pipman76
    pipman76 Member
    alabama
    1972 mav
    thanx or the pictures and diagrams but i still cant clearly see ,i think these diagrams are for 71 up heater outlets and inlets the 70 heater coer comes out of the fire wall a little differently,they are stacked one just above the other not side beside
  4. rthomas771
    Here is a pic of my '74 heater hoses. I replaced the original hoses and this is how they were run.
  5. pipman76
    pipman76 Member
    alabama
    1972 mav
    i cant see these connections at the firewall ,but hey nice looking engine
  6. rthomas771
    Try this pic.
  7. Bryant
    it really doesnt mater. the heater core will heat up when hot water goes through it. its not directional.
  8. rthomas771
    It matters if you want the water going to the heater core that just passed through the block or if you want water that just passed through the radiator.
  9. PaulS
    The bottom heater hose goes to the engine and the top hose goes to the pump. The pump is sucking and the engine has pressure. This will fill the heater core completely evacuating the air from the heater core.
  10. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Also it matters which direction if you have a heater control valve. I would rather have the HCV on the hose coming from the engine, so I'm not pressurizing my heater core all the time...
  11. Bryant
    the heater core does not controle the direction of flow. the water pump does. the water that goes to the core will allways be comeing from the block and going to the the heater core then back to the water pump.
    pauls sugestion of haveing it goto the bottom and out the top to bleed the air is a very sound suggestion.
  12. rthomas771
    I don’t believe I said that. Of course the water traveling in the heater hose to the heater core will always be running in the same direction. PaulS described it better. The water needs to fill the core so it is feed through the bottom of the core and exits from the top. I have noticed on my Falcon the heater kicks out hotter air if it is plumb this way.
  13. PaulS
    Having the heater control valve on the line from the engine is also a good point. I thought that only AC cars had the valves - that would explain why mine doesn't have one.
