Heater House Grommets - available??
Discussion in 'Technical' started by dmhines, Dec 1, 2002.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Anyone know where to get the Heater Hose Grommets that go in the holes in the firewall where the heater hoses pass thru?? Doesn't appear Mustangs used them - I can't find mention of them in any catalog.
    Thanks - Dan
  2. Mavaholic
    They are not available anywhere. I tried like crazy to get these reproduced but it would have cost me about $3000 to set up the tooling and then I would have had to buy a minimum of 500 pieces. I passed. I found some gromments at Restoration Specialties. They have an online catalog. Check the link. If I remember correctly the firewall hole is 1 1/4". Check to make sure. I got some gromments from them to fit this hole. The center was too small but I took a Xacto knife and cut the inside opening till the 5/8 heater hose fit pretty snug. Worked pretty good.
    http://www.restorationspecialties.com/
  3. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    You can get all size grommets from "KAR Products"
  4. dmhines
    Cumming, GA
