I found a NOS Heater panel (the panel for the fan speed, warm/cool, vent controls) this panel isnt lining up very well. every time i try to turn on the fan speed the panel wants to pop out, and ive pushed as hard as i can to make sure the clips are in there proper spots... Is that a common problem? If so how do you fix it? Tanks, Chaz.
They sure are... They will snap in, but when you goto turn on the fan the plate pops out, i snap it in at the top, it snaps out the bottom, if i use ALL my fingers to snap it in at the top and bottom it will hold, until i move a lever.. CHaz.
I used a little strip of industrial strength velcro on the top and bottom of the panel. You can't see it, and it holds the panel in very well. Plus, if I need to take it out, it is a lot easier than trying to get the pegs out. Mine had the pegs broken off when I got it, so it did this out of necessity. Good luck!
Well i kinda stretched the metal tabs and it held better, but 1 broke and 1 ALMOST broke. but it fits better.... If the tabs break off i might do the velco thing! Thanks Guys! CHaz.
