HEI vs DUI
Discussion in 'General Maverick/Comet' started by Mhackett, May 14, 2014.
  1. Mhackett
    Mhackett Member
    Rochester, NY
    1969.5 Maverick
    Greetings all. While I realize a DUI is only slightly better than a DWI, it's a lot better than a stock points dizzy. I've been looking for a new one and a little advice might be useful. The choice is between an HEI and the DUI. Classic inlines boasts some serious performance with the DUI, however, it doesn't really stand out over the HEI from CRT Performance. The only visible difference is about $200 and change. I have a 200 inline so I don't need a high rpm dizzy. Thoughts?
  2. rthomas771
    Go with a Duraspark. The Duraspark is a newer/better design than either the HEI or DUI.
  3. ResidentEvilRoc
    ResidentEvilRoc Got bit by the HP bug.
    Rogersville, TN
    1973 Ford Maverick
    The HEI types don't allow much clearances. With the coil being on top, the caps are a lot larger in diameter.
  4. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Build a HEI Box
    I converted my DUI box to house an HEI module.
    It's real easy! I put the DUI into the oven at around 300 degrees. (Bake until golden brown - lol) It smells up the kitchen, though.
    Take outside, and using a knife, screwdriver, putty knife, etc. the "guts" come right out.
    Clean it up, make an aluminum "pad" for the HEI to mount on; and it wires right up (using lugs).
    Yes, the DUI is electrically a better circuit - but, considering cost and ease of replacement - I think that the HEI is a better deal.
    (I work in electrical engineering for Garmin).
  5. Mhackett
    Mhackett Member
    Rochester, NY
    1969.5 Maverick
    I ended up getting the HEI. The price with wires was a way better deal than the DUI.
  6. scooper77515
    I have HEI on mine, 5.0, and it spins fine to 6500 rpms. I was afraid I would lose some power up top, and maybe lose some rpms, but it feels as strong, if not stronger, than it did with the old pertronix-in-stock-distributor setup with MSD 6A. No longer using the MSD box, either.
    But it is a BIG thing under the hood.
    Had to lose my round air cleaner and move some other things around to fit it in there.
  7. lm14
    lm14 Member
    Iowa
    Keep the small diameter, stock appearing distributor and out a Pertronix in it.
    HEI belong on Bowties, period. Hate the look of that big lump sitting on a Ford engine.
    SPark
  8. Mhackett
    Mhackett Member
    Rochester, NY
    1969.5 Maverick
    I've got an I6. Plenty of room. :)
  9. rthomas771
  10. groberts101
    groberts101 Member
    Minneapolis, MN
    The coil packs are always going to inherently be too small by design. And they are fugly too!
    Any mag pickup style disty(Duraspark is a good tough design) with an external coil will beat those modular "all in one" units by a country mile. Unless of course.. "good enough".. is good enough. It's not like many ever care how their engine looks anyways. haha.. I kid.
  11. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Don't drink and drive :)
  12. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    personally ive used DUI for years on my impala, the whole idea of dui, is to have your advance curves set. they do all the calc's and modification for you. ive had alot of luck with there products. they are expensive. they are located here in memphis so i can just drive to there store and pick stuff up.
  13. Jamie Miles
    Alto, GA
    I've had a few
    HEI sucks.. especially the ones Summit sells. I had one in my '72 C10 that had a '89 5.0 H.O. motor out of a Mustang in it. It worked fine for the first year or so, then it started chewing the upper shaft bushings. I replaced the upper bushing 4 times in less than 3,000 miles before literally throwing the distributor in the trash. When the bushing wore down it would allow the reluctor wheel to drop down on the pickup coil and would start chewing that up until it just randomly lost fire and left you stranded with no warning... On the other hand, the Duraspark II/MSD6 combo in my Maverick has been in the car through three engines and over 200k miles and has NEVER given me a single problem. Hell, the MSD plug wires on the car right now have over 100k on them...
  14. scooper77515
    Hmmm. I am using the Summit HEI right now. Fairly new, and no problems yet. Hopefully they rectified the problem since you bought yours.
    So far, I am happy with it. Less wires, spins fine to 6500 rpms. everything I need, currently (pun intended).
