Hello, glad to be here, help.
Discussion in 'New Members Forum' started by johnlilui, Apr 16, 2007.
  1. johnlilui
    johnlilui New Member
    Cali
    1976 Stallion, stock
    I have a 1976 Stallion, 200cid that is all original. When I got it, it had no emissions left on it. I've found most of what I need to get it smogged in Cali but I'm still missing a few things. I need a heat oven, both of the steel tubes from the exhaust manifold (one for the EGR and one for the smog pump), an upper bracket for the smog pump (it looks like mine was mounted on top of the engine on the drivers side). Any help you guys can give me is greatly appreciated. :hmmm:
    John
  2. JnkYdMod
    JnkYdMod Member
    Curlew Washington
    1976 Maverick
    What is a heat oven?
    Lou
  3. johnlilui
    Cali
    The heat oven is the piece of sheet metal on the exhaust manifold that connects to the air cleaner. I may be calling it the wrong thing.
    John
  4. JnkYdMod
    JnkYdMod Member
    Curlew Washington
    1976 Maverick
    I'm drawing a blank:huh:
    Someone help this guy!!!
    Lou
  5. don graham
    welcome to the board.:Welcome:
  6. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    I think its called a heat riser. I have seen flexable ones that are universal sold in the "help"/motormite section at most auto part stores.
    Welcome fellow Californian :tiphat: , where you at?
  7. johnlilui
    Cali
    Right now I'm in Murrieta but soon to be in SD - livin on a ship.
  8. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    welcome to the board~!
  9. JnkYdMod
    JnkYdMod Member
    Curlew Washington
    1976 Maverick
    Oh! heat riser. No I've never seen one on a Mav. Don't know if they ever came with one. I'm in a no smog regulation area, so that stuff has been long stripped off!!!
    Lou
  10. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Auto-krappers have them......heat OVENS
  11. Mavaholic
    Never heard that term before.
    Dan Starnes runs the Stallion registry.You might want to contact him.
    V8stallion76@yahoo.com
  12. JnkYdMod
    JnkYdMod Member
    Curlew Washington
    1976 Maverick
    Learn something new every day you listen!!!
    I have two '76 Mavs, and no heat oven between them?
    Lou
  13. Jean Doll
    Palmerton, PA
    The 76' Stallion I used to have had a heat riser on it. But then again it still had the original 250 and all the smog junk still on it.
  14. Craig Selvey
    I found an upper smog pump bracket. Email me directly (see below) if you are still looking for it.
  15. maverick75
