hello. I need technical help.
Discussion in 'New Members Forum' started by jmitchell, Mar 6, 2011.
  1. jmitchell
    jmitchell New Member
    Papillion, Nebraska
    1976 mercury comet
    Hi, I am new to this site. I have owned 2 1970 mavericks in the past and have recently purchased a 1976 comet. The cable that goes to the warm/cool nob appears to be disconected at the nob end. Do the nobs pull off to remove the panel behind it? I tried to pull them off, but not too hard becouse I was afraid of breaking them. I am excited to be a part of this forum. I was googleing my comet and found you. Thanks for letting me take part .
  2. Acornridgeman
    Wisconsin
    They pull off. Sometimes they can really be tight, but they will pull off. When you remove the heater panel, it must come straight out from the dash without twisting it. There are 5 plastic pins that break off very easy if the panels gets crooked.
  3. injectedmav
    injectedmav Member
    Georgia
    and it falls off every time you change the temperature after that too! :16suspect
  4. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    Mine falls off too. I was thinking about some neodymium magnets I pulled from an old hard drive. I should be able to break them small and keep them very strong. I havent taken the plate off yet to look, but I hope there is some metal inside and back to stick it too.
  5. injectedmav
    injectedmav Member
    Georgia
    That's a good idea. Some hardware stores sell the really strong magnets with holes in the middle and I have had some luck lightly sanding the back and using a good epoxy to mount them to plastic. (Ford uses them on newer headliners on the Edge and Flex around the roof opening panels) The IP is steel right behind the plate but the control fixture is pot metal.:thumbs2:
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Welcome to the site!!!!!
  7. mav1970
  8. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    welcome from Falling Waters,Wv:Welcome: Jim
  9. bri
    bri midnight special
    mission city b.c. canada
    71 comet GT. 414 cu, c-4, 9+, spool 3.25, 35 spline axles, back halved,12 point,,4 whl wilwood discs, 3 link,tubbed. 73 comet sdn 302, 76 comet 2dr 6 cyl, 84 z-28 468. 98 f-150 4x4 5.4, 98 fld 120, 500 detroit. 09 jeep grand cherokee.
    welcome .. a little dab of two parts epoxy worked for me..not to much , or it won't set up properly. and if you need to get it off in the future your hooped..just kidding lol..work it a bit and it will come off.
  10. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    :Welcome: from SoCal
    Mine were really hard to get off. I literally had to use a claw hammer to get enough leverage behind them to pull them off (put some tape on them to protect). I won't putting them back on until I'm sure I'll never have to take them off again.
