hello to all and a tech question
Discussion in 'New Members Forum' started by Lincolnlover3, Mar 13, 2012.
  1. Lincolnlover3
    Lincolnlover3 New Member
    New York
    1973 Maverick 4Dr 250 CI, 1963 falcn 2DR Hardtop, 2004 T-Bird
    Hi All,
    I am new to the forum - I have a 1973 Maverick 4 door with a 250 inline six - I am hoping someone here can help me - the car idles and drives great, but when you come to a complete stop, then give her some gas, the car acts like she doesn't want to take the gas, like a hiccup (I just changed the filter thinking that was the cause) and then she takes the gas a goes, but this happens every time i come to a complete stop, or make a slow turn - any advice would be greatly appreciated!
  2. Earl Branham
    Lugoff, SC
    Check the accellerator pump diaphram and adjustments. And welcome, we are glad to have you with us!
  3. mav1970
  4. Mavman72
    Ditto the accelerator pump adjustment...Also...If it likes to cut out around corners or abrupt stops...float level may be too low.
  5. Lincolnlover3
    New York
    thanks
    Thanks everyone - I will try these over the weekend! Thanks again - I appreciate the help!
  6. Mavman72
    Make shure you only adjust one thing at a time and drive it. (Do the accelerator pump first) and see what you get.
  7. Lincolnlover3
    New York
    thank
    will do - I figured the accelerator pump was the easiest to start with too - I don't want to take the carb apart yet (if it happens to be the float, I figured I'd do a full rebuild while I was at it)
  8. don graham
    Welcome to the board.:)
  9. 71gold
    :Welcome:...from Maconga, U.S.A...:Handshake
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  11. mojo
    I figured I'd do a full rebuild while I was at it)[/QUOTE]
    I wud agree on the pump, and maybe, the float needs adj. or has a hole.
    I wud also do a complete carb kit if I took it apart.
  12. simple man
    simple man Member
    Bunnell,Florida
    Welcome, and say hello to the Carter rbs blues! I've been trying to get this out of mine for years! It's just a poor design. I would get a carb kit, and replace the accelerator pump plunger. That will be a start. They wear out and don't provide enough fuel on acceleration. I have never been able to get mine " perfect ", but at least now it's acceptable! :)
  13. Mercurycruizers
    Venetia, PA
    :Welcome:to the board.....
