help cant find gas tank
Discussion in 'Technical' started by justin, Mar 11, 2011.
  1. justin
    justin Member
    okc
    73 maverick grabber
    will a 76 maverick tank fit a 73?
  2. 71gold
    ...using the search funtion helps a lot also in finding answers to questions...
    I found this by using it.
    Yes...I just installed one in my '73...:Handshake
  3. CaptainComet
    There are new tanks made for the later year Mavs. Swapping a Mustang tank in can be good too. There is a tech article on that posted here.
    I highly recommend going with a new tank instead of a used one. A 30 year old used tank is bound to be cruddy, even if it looks great externally.
  4. justin
    justin Member
    okc
    73 maverick grabber
    Thanks you guys are awsome
  5. mean_maverick
    just use the later straps 75-77 with the later gas tank, or longer bolts with ur currect straps and it'll bolt right in
  6. justin
    justin Member
    okc
    73 maverick grabber
    new problem.......sending unit and float
    got gas tank all cleaned up.......but now i cant find a sending unit...............it never stops
