Help decoding Mustang II info..
Discussion in 'Other Automotive Tech & Talk' started by Matterick, Mar 12, 2013.
  1. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    From what I've heard..some of these mustang II's have a desirable 8 inch with some decent gears..I just have no idea how to check. Can it be found on this?
    It's an AC car btw..
    image hosting
  2. Matterick
    Lake Stevens WA
    crap I just found the info and it looks like its just an open rear with 3:40's..BUMMER! none the less, do these rearends bolt in the Mav's (direct)
  3. yellow75
    Tillamook Oregon
    According to info I just found it would be 57" wide so it would be 1/2" wider than the Maverick is suppose to be, I did not find info on the spring perch centerline. It would be a 4 lug bolt pattern. 3.40 gears are highly sought after though and would interchange.
    Spring perch centerline on Mii is 42 1/2" Maverick is 43" close enough to work
  4. Matterick
    Lake Stevens WA
    Right on! thanks for the info Mike! just what I needed:Handshake
