Help Help HELP. torque specs
Discussion in 'Technical' started by 1974fordmaverik, Apr 2, 2010.
  1. 1974fordmaverik
    1974fordmaverik Member
    huber heights Ohio
    74 Maverick
    i need to know what the torque spec on a 1974 maverick pitman arm
  2. rthomas771
    Some where around 100 ft lbs
  3. 1974fordmaverik
    huber heights Ohio
    74 Maverick
    is this to pitman arm to control valve??
  4. rthomas771
    No...Pitman to sector shaft on gear box. The Pitman to Control Valve is 35-47 ft lbs.
  5. 1974fordmaverik
    huber heights Ohio
    74 Maverick
    thank you so much my book didn't have it in there because it is all cars from 69 to 79 and it wasn't that descriptive just for the pitman arm
