Help! How do I remove/seperate the engine wiring harness
Discussion in 'Technical' started by murphypatsara, Oct 27, 2016.
  1. murphypatsara
    murphypatsara Member
    image.jpeg I am trying to remove the engine wiring harness from my maverick. Can someone tell me how it seperates at the firewall as shown?
    Thank you
  2. yellow75
    Tillamook Oregon
    There is a bolt that goes through the fuse block and holds it to the outer connector then it is just a matter of wiggling it out
  3. murphypatsara
    Thank you!
  4. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hey Murphy :
    It may be a good idea to ' TAKE PICTURES ' of the Harness and its Connections under the dash ..and at the Firewall BEFORE removing anything ! It may aid you in re-installing important wires ! Just a thought.
    Cometized
    (Chip_
    mojo likes this.
  5. murphypatsara
    Good idea! I have taken several along the way and will continue to do so.
  6. Craig Selvey
    Once you remove the bolt in the fuse box....pull the fuse box out of the firewall. Then there are two clips you need to pry on from the "inside" in order to get the engine side of the plug out of the firewall.
    71Mavrk likes this.
  7. murphypatsara
    Appreciate the additional info!
