help, I need pictures of seatbelt design
Discussion in 'General Maverick/Comet' started by xpsnake, Apr 4, 2004.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    in need of seat/shoulder belts, where to look?
    My recently purchased 1977 Ford Maverick had it's shoulder belts chopped off. They literally cut the seatbelts right off, what other ford cars had these same belts?
  2. Jean Doll
    Palmerton, PA
    These came out of a 77'Maverick. I don't know what other seat belts would work on a Maverick.
  3. xpsnake
    xpsnake Bruce
    does that unit have a part # on it?
  4. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Anybody know if the front seat belt parts like pictured above are the same on both the 2 door and 4 door cars?
  5. Craig Selvey
    4 door is different.
    I have some seat belts like that I can sell. I think I have blue and a lite tan. they are used. Email me if interested.
    cselvey@netdirect.net
  6. Sam M.
    Sam M. Just a nobody
    Southern NJ
    Has anybody ever had any luck retrofitting the newer retractable shoulder belts (like pictured above) into an older Mav? I have those stupid clip-together units on my '72 that drive me crazy. I have a set of the newer ones but I notice that it would take quite a bit of modifying to make them fit. Anyone ever done it?
    Sam :)
  7. Mavaholic
    It would take some modifying because the sill plate is shaped different. The retract mechanism is recessed into it.
  8. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Aftermarket...
    ...do a Google search on seatbelts for early Mustangs.
    There are companies that make retrofit seatbelt kits
    for older cars that allow you to add a shoulder harness.
    You may be on a budget, in which case this may not
    help you.
    Try: Mustangs Unlimited.com or look up National Parts Depot.
    Seth
  9. auburn
    auburn Member
    Waterloo, Iowa
    70 Maverick
    XP...
    I have the shoulder straps from my 1970 Maverick that I'm taking out. They're black in color. They are going to be replaced with a 5 point belt one each side.
    Let me know if this is what your looking for.
    rscally48@mchsi.com
