HELP I need Water Pump Bolt Diagram
Discussion in 'General Maverick/Comet' started by jncastell, Jan 30, 2011.
  1. jncastell
    jncastell Member
    Ogden, Utah
    1974 Maverick Grabber Clone
    :huh: Hello folk's I'm having the same problem as this member below had, lesson learned but knew in the back of my head while replacing the master cylinder, all 4 wheel cylinders, rear brakes, some hoses and 2 electrical shorts, and the water pump thinking, John dont buy a remanufactured pump spend the extra $20.00 buy it new. You know it's going to go out in the middle of winter. But now It's warmed up out side and I'm fustrated I'll check for an answer throughout the day, a bolt diagram would be appreciated greatly thanks!
    I need a Water Pump Bolt Diagram was changing water pump and everything was going good till I noticed when I was putting water pump back in that not all the bolts where the same size some where just a 1/4 of a inch longer. Now I'am stuck with my car apart and no idea where these bolts go if some one could hook me up with a water pump bolt diagram I would be much appreciated thanks!
  2. Dave B
  3. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    I've used a coat hanger before, it saves some frustration. Cut the bottom out of the hanger, stick it in the hole (with pump & brackets inplace), mark it with a sharpie, then compair it to the bolts you have on hand.
  4. jncastell
    jncastell Member
    Ogden, Utah
    :thumbs2: Wow that was quick thanks both to both of you guys! The fog's lifted and th temperature is rising outside we may hit 40 degrees. Can you beleive that fog in Utah? It might be more of a temperature inversion.
