Help Identify This Part 1976 Maverick 4 door
Discussion in 'Technical' started by pr142, Jan 31, 2008.
  1. pr142
    pr142 Member
    Los Angeles
  2. Craig Selvey
    I have no idea what that is. :huh:
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Aftermarket Cruise Control?
  4. GTwannabe
    GTwannabe Member
    Acworth/Kennesaw, GA
    94 mustang GT, '73 Comet GT 302 toploader 4-speed
    :hmmm: dont know. BOMB???:outtahere:well its prob disarmed now thanks to the rag joint and all.
  5. rayzorsharp
    That would be my best guess too. I parted out an early 80's Mustang a few years ago that had a similar part that was a cruise control unit. The Mustang unit was mounted in about the same area but was on the tire side of the fender apron. If so, there would have to be a cable of some type going to the carb.
  6. Bob Wiken
    Fayetteville, Arkansas
    Flux capacitor housing
  7. comet666
    comet666 RAISE HELL AND DRINK WINE
    Sweden/Gothenburg
    Comet -74 Inline Six 250, 4.1 AT
    Time travelling device..?
  8. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    If not a cruise, It may be a gas, power saver they marketed back then, when your engine vacuum went down from hitting the gas pedal, it would shut off your air conditioner, freeing up more horsepower. What all kinda lines are hooked to it?
  9. pr142
    pr142 Member
    Los Angeles
    Has two vacuum hoses and 6 wires, 4 wires (red, orange, green, and yellow) to one plug and 2 wires (brown and black) to a 2nd plug. One vacuum hose to the manifold and the other hose appears to be a vent hose. This car has been in the family since it was purchased new at the dealership in nor cal.
    I know that my dad did install a cruise control in the late 70's...maybe this is a remnant of that. I Did not see any connection to the carb.....just this "thing" the hoses and wires..
  10. pr142
    pr142 Member
    Los Angeles
    Could be. My dad did install a cruise control in the late 70's. Never really worked to good. I had unhooked the "inside the car" stuff years ago. Maybe this is part of it. No connection to the carb though.....
  11. Columbus Comet
    Columbus Comet Member
    Columbus, OH
  12. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    looks like the control unit
    To an after market cruise control, there is an diaphram that is vacum operated that connects to the throttle via cable, or chain (yes chain). The one I ended up with had an input and output from the spedometer cable and it actually worked pretty good, they were made by Dana and you could actually find them on some other brands of cars and trucks (GMC, Jeep) in the 70's
  13. pr142
    pr142 Member
    Los Angeles
    I think you are 100% correct. Thanks!
  14. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    Its a Fetzer valve!
