HELP NEEDED Power to manual steering swap
Discussion in 'Technical' started by ray, Jul 8, 2014.
  1. ray
    ray Member
    portland
    71 grabber
    I'm thinking of changing my power steering to manual. I currently have headers with the drop down bracket. Can anyone give me a bit of help. Will the manual setup fit with my headers? And what total parts do I need? Any roadblocks??? Has anyone done this, and is it better?? Any help greatly appreciated. - Ray, proud maverick owner.
  2. davidjfranz
    davidjfranz Member
    Chicago,Illinois
    1971 Maverick 15,000miles!
    Steering swap
    I did a swap like that years ago on a 73 Comet. I used a manual steering pitman arm and center drag link. It worked for me. I think the idler arm should also be changed.
  3. ray
    ray Member
    portland
    71 grabber
    Did you leave in Power steering box? Did You have headers? Was it better? Thanks so much for your time.
  4. davidjfranz
    davidjfranz Member
    Chicago,Illinois
    I had Hedman headers. I left the Power steering gear box and just swapped the pitman arm. It was better.
  5. werner
    werner Member
    pa usa
    71 GT mercury comet
    i have manual steering in my 71 comet and i hate it. i'm looking for power steering . i thing manual is only good for racing. let me know if you want to get rid of your setup.
  6. 71gold
    I swapped mine to manual, was tired of the oil leaking. drag link and pitman arm was all I changed...:thumbs2:
    I liked it so much that I did manual when I swapped to rack n pinion...:bouncy:
  7. baddad457
    I did the same with my 77. No leaks now. Steering is a little hard when the car is not moving is the only drawback.
