help please
Discussion in 'Technical' started by gwil81, Feb 28, 2008.
  1. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    im trying to put a aod tranny and a 1989 5.0 rear end with 3:73 in 77 maverick with a 289 ?
  2. newtoford
    newtoford Member
    New Castle Delaware
    are you sure its a 289? mavericks never had those stock.
    to get a AOD in your going to need a custom tranny crossmember. 71gold has a few i believe. as far as the mustang rear it should be a 8.8 and at the very least its going to need to be fitted for the correct spring and shock mount locations assuming its the right width to fit under the car. if not it'll need to be lengthened or shortened accordingly.
  3. 71gold
    :Welcome: :Handshake
    is it an AOD or an AODE? either way i have a crossmember for it. if you have a 6cyl.now, you will need some mav.only v8 parts.
    good luck and enjoy...
    ...Frank...
  4. Chinguschild
    Chinguschild The Bass Player
    Orcutt, Ca
    71 Grabber
    Where did you get the crossmember? I been considering the aod swap.
