I removed the plastic seal from the window frame, Unscrew the lever on the back that keeps the window closed push the window open to the outside and then on the oposite side (Front of window) there are screws that hold the front hinge. (You will see the screws when you push the glass out and away from the window) remove them and that is it. Hope this helps.
