Help! Upper Control Arm Removal
Discussion in 'Technical' started by boss427, Jun 17, 2012.
  1. boss427
    boss427 Member
    Ames, Iowa
    1974 Ford F100: 427 Clevor, C6, 9 inch. 1972 Maverick Grabber: 351w, T5, 9 inch
    So my passenger upper control arm bushings squeak with every little bump. I ordered the MOOG kit from OReilly's to replace the rod and use rubber bushings. The kit is supposed to be in this afternoon, so I'm in the process of taking the old one out now.
    My question is, are both bushings right hand threads, or is the bushing towards the back reverse thread? I bought a big 1 1/4" wrench to loosen them with and I've got the front one loose. Should I start turning the opposite way on the back one, or continue to work towards a hernia? :huh:
    The upper control arm is still on the car to aid as a vise.
  2. Dave B
    You won't be able to remove them with it in the car.
  3. rthomas771
    Really doesn't matter...the threads are going to break off once you start turning it, I think they are righthand threads
  4. blugene
    I sure hope the spring is out..
    I have been able to loosen them in the car but that was about it.. Right hand threads..
  5. blugene
    You might look real close at the ends. When I replaced mine I tacked them with my welder. Never know if someone has done that to yours.. Going rubber next go around on mine..
  6. boss427
    boss427 Member
    Ames, Iowa
    Thanks for all of your help! The shaft kit didn't come in today, so I will continue with it tomorrow.
    Oh yeah, the spring was definitely out! Those things make me nervous.
  7. blugene
    Might consider applying some Sil Glide to the rubber surfaces and the washers for the bushings. Help them not squeek and glide smoothly..
  8. Fordcustom
    Fordcustom Member
    Callahan, FL
    72 maverick
    A whole new arm with ball joint is almost as cheap as the bushing kit. And you don't have to fight them plus you get a new ball joint
  9. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Spray them with PB Blaster tonight that should make things easier tommorow.
    Which brand and part number shaft kit did you order?
  10. Fordcustom
    Fordcustom Member
    Callahan, FL
    72 maverick
    I ended up getting a kit on eBay from someone else that didn't do their disc swap. But rockauto.com has great prices and there is a 5% off code on retailmenot.com
  11. boss427
    boss427 Member
    Ames, Iowa
    I ordered the MOOG K8233 shaft kit.
  12. 1973CometGT
    1973CometGT Member
    Orem, Utah
    1973 Mercury Comet GT
    Update
    How did your project turn out?
  13. junrai
    junrai Member
    rancho cordova ca
    I got both upper control arms with new bushings and ball joints for $135 shipped from ebay
    I did it just to replace everything that couldve or would been breaking down in the near future
  14. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    That was my thinking when I did that plus a lifetime warranty.
