help with installing Jazz racing seats
Discussion in 'Drag Racing' started by maverick7072, Aug 24, 2016.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    I plan to buy to Jaz plastic drag seats to replace the bench seat in my maverick,can anyone who has did this install explain to me how they mounted the seats,the mounting brackets jegs and summit sells are for a flat floor board ,I still have stock floor pans!!
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    I had that setup in mine at one point. The angle brakets are adjustable enough to get them about right. They just don't move.
  3. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    ok thanks!! I plan to run seat adjusters as well mounted between the seat and mounting brackets
  4. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    We used to place a flat bar up front and a piece of angle aluminum at the back spaced the angle aluminum so it would be level
  5. Shorty
    Shorty Member
    Lafayette, In
    Here is a picture or two of my installation. I found 'dimples' on either side of the tunnel where the inside bolts would have been had my car been equipped with bucket seats from the factory. I used Summit steel angle brackets, sliders and some plate steel I had laying around. For the difference in floor height I used some 1" square tubing cut to fit. I also used Grade 8 hardware and large washers on the bottom of the floor pan where my new bolt locations were. They 'sit' pretty good but I don't think I would like them for longer trips.
    Bruce
  6. mav man
    mav man Member
    wi
    70mav
    Yeah they don't look all to comfortable. Is there any padding at all?
  7. Shorty
    Shorty Member
    Lafayette, In
    The padding is built in to the cover but its thin. I'm thinking about getting some foam padding to attach to the back of the center section of the cover. But for driving around town the seats are very comfortable.
    Bruce
