Hi, I been trying to find a diagram for a 71 maverick instrument panel wiring harness.. I need to know what wires are what. thanks for any help
thanks i looked at that already but didnt see where it told me what wire is what that goes into the instrument panel.. will it be the wire color it says from the part like the fuel tank one be yellow and white? thanks
i traced the printed circuit on the interment cluster to determine which wire when to what. its not to hard. you will find one circuit that is the ground circuit that goes to every thing. then you just trace each circuit to the connector plug and that will tell you what you want to know.
