Help with lights
Discussion in 'Technical' started by danny, Jan 25, 2005.
  1. danny
    danny Member
    donna, Tx
    77 maverick
    What funtion do the clear rear lights with parking/stoping lights on the maverick do?? The only ones that turn on are the red ones in the back? I put in a new light bulb on the 2 and still nothing:confused:
  2. rayzorsharp
    Those are your back up lights. They should come on only when your car is in reverse and your ignition switch is on.
  3. danny
    danny Member
    donna, Tx
    77 maverick
    They dont turn on??
    Thats wired i don't see then turn on with the igition switch on:confused: Do you have to have the car on for them to turn on? I haven't tried looking at them to see if they turn when the car goes in reverse but i'll check again thanks:D
  4. 71gold
    reverse light switch might be bad or needs adj....put the car in reverse, turn the key to on and they should be on (y) ...frank...
