help with part identification
Discussion in 'Technical' started by EFIMAV, Nov 23, 2005.
  1. EFIMAV
    EFIMAV Member
    Davenport Iowa
    I'm almost 100% sure this is a V8 clutch setup for a maverick. I would like to confirm that with someone who is a little more familiar with these parts. Thanks
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Yup ... sure is ..... and includes all the mounts ..... The bushings from the engine side mount are not in the picture ...
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I have seen that large 'ball' type engine side pivot before, but mine does not look like that.
    Mine is a straight 'stud' off the side of the block, with a large ball shaped bushing slid over it. Hard to explain, but it is a thick spherical plastic bushing.
    Dave
  4. EFIMAV
    EFIMAV Member
    Davenport Iowa
    DM, the bushing for the block pivot ball is still in the Zbar. It needs to be replaced. Thanks to both for the info. just wanted to be sure. Ratio, the z bar looks right, correct?
  5. Mavaholic
    Looks like mine so it must be right. :D
  6. ratio411
    ratio411 Member
    Pensacola
    Oh yeah...
    That's the stuff.
    You have a complete set from what I can tell. Except maybe the pedals.
    Dave
    Edit: I just remembered, the Z bar has a big return spring that goes to the firewall.:wave:
  7. EFIMAV
    EFIMAV Member
    Davenport Iowa
    figured the pedals are no big deal since I can use a 6cyl setup
  8. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Looks just like the setup that I have.
  9. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    yup, dats it.
    Dan
  10. EFIMAV
    EFIMAV Member
    Davenport Iowa
    thanks to all and happy Thanksgiving!
