help with toploader
Discussion in 'Transmissions' started by jean282, Jul 23, 2009.
  1. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    hi i bought a toploader and a bellhousing from a 72 or 73 mustang and i want to use it on my 73 comet. Can i use a newer motor with the toploader engine who are 50 oz balanced ?
    My bellhousing is 1 inch more large that my c4. do you think i will have problem using headers ? thank you
  2. rthomas771
    The transmission doesn't care what balance the engine is. The main question is what year is your bellhousing. The T-5 era bellhousings are too deep and the transmission input shaft will fall short and not reach the pilot bearing
  3. baddad457
    As rthomas stated, engine imbalance is irrelevent to the transmission. It IS relevant to the flywheel imbalance. Sounds like you've got a 164 tooth bell, so you'll need a 164 tooth flywheel to match the bell, with the correct imbalance to match the engine. The headers may have a problem with the bigger bell, if you already have headers and they were designed for the smaller bell.
  4. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    thank you for the answer. i dont have headers right now but i will buy some later but i want to know if i can use headers whit 164 t flywheel if i cant or i will get bid trouble i will try to find a 157t bellhousing. Its possible to change the balance on a flywheel for exemple 28 oz to 50 oz ? thank you
  5. baddad457
    Yea, it is possible, but easier to do the other way.....50 to 28. In doing a 28 to 50, you have to add weight. If you need a 50 oz wheelm, buy a 50 oz wheel. Same one for a late model 5.0 with a T-5 will do if your motor needs a 50 oz wheel in a 157 tooth size. You will just have to use the 5.0's diaphram style pressure plate, in place of a long style P/P.
  6. rthomas771
    Headers and flywheel teeth would be the least of your worries. If the bellhousing is wrong you won't be going no where.
