Help
Discussion in 'General Maverick/Comet' started by KauaiHi, Nov 4, 2011.
  1. KauaiHi
    KauaiHi Member
    1975 Mercury Comet 5.0 V8 2bbl (4door)
    I'm all set right now to finish my transmission job, but cut seem to figure our how to put my spring valve back in before my filter... I'm thinking it goes 1)transmission, 2)valve (plunger side up) 3) spring 4) filter
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You are correct
    Here is a thread discussing it
    http://mmb.maverick.to/showthread.php?t=1591&highlight=spring+transmission
    Also found this on a forum
    The metal plunger goes in first with the flat, cupped shape, up and the spring on the bottom. There is a little finger on the plunger that goes inside the spring. These go in the hole and are held in place by the tab on the filter.
