HHEELLPPP!!!!! motor mount bolt???
Discussion in 'Technical' started by Mav_beater76, Aug 16, 2005.
  1. Mav_beater76
    Mav_beater76 Member
    williamson, Wv
    1976 Ford Maverick 4.1 V6
    I need to find a way to fix (get it out!)
    I was driving the car tonight and the bolt that gos into the engine from the motor mount broke off, so i need to find a way to get the rest of the bolt out to replace it.... :huh: :49: I'd be most greatful for any help
    :bananaman
  2. 71gold
    do we know "why" it broke???:huh:
    i would take and jack that side of the motor up and take the motor and frame mount off. that will give you a little more room to work. being it is a large bolt that makes them not so bad to back out. let us know what it looks like after you get everything out of the way... maybe post a pic...work safe...frank...:bouncy:
  3. 71gold
    :huh:
    have you had a chance to look at it yet???
  4. Jamie Miles
    You have a 6 cylinder... those bolts are made to stand up to hundreds of horse power, what the heck were you doing to break it?
  5. Mav_beater76
    Mav_beater76 Member
    williamson, Wv
    (go speed racer, go speed racer, go speed racer gooo)
    no really, i was delivering pizza, dropped her into reverse, and the bolt snapped.
    i noticed today that it was missing the bottom bolt , so all that hp was hittin on that one bolt,...plus i dont think it was the strongest bolt .....i bought some grade 8's to go back in there place. i cant get the dang thing out... so i cant make the money to buy that comet i found for $200 need that loot.
    I cant get a drill in there to drill it out so now i'm just kinda stuck....
  6. 71gold
    "got a pic.":huh:
    ...frank...:bouncy:
  7. Mav_beater76
    Mav_beater76 Member
    williamson, Wv
  8. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Do you have access to a dremmel tool? If so cut a slot in the top of it and use a screwdriver to back it out. I doubt that this particular bolt would be siezed up.
  9. Mav_beater76
    Mav_beater76 Member
    williamson, Wv
    I bought a set of those bits, that you hammer in a turn with a wrench to back it out, but i cant get a ______ to get in there to drill a hole in the bolt to do it,...
    my brother has one ,but he cant find it so I can't cut a slot out for a screwdriver
  10. maverick1970
    Missouri
    On larger bolts you can sometimes use a small chisel to back the bolt out. Is it broken off flush with the block?
  11. Mav_beater76
    Mav_beater76 Member
    williamson, Wv
    yeah, it snapped off right at the engine,:smash:
  12. Acornridgeman
    Wisconsin
    maverick1970 has 2 good ideas with a Dremel tool and using a punch to start it turning. If you have a friend with a decent amount of tools, odds are they have an angle drill adapter. Rental centers might have one too. That is what you need to get into there for an easy-out.
    This one is from JC Whitney
