Hi
Discussion in 'Transmissions' started by jaycee21, Oct 24, 2007.
  1. jaycee21
    jaycee21 Member
    Houston
    Maverick
    I have a 6 inline engine i dont know how big? Where do i find that? Also i want to put a bigger engine in my 76? What is the best kind and where can i get a cheap one? Can i keep my tranny or do i also need a new one? :huh:
  2. 71gold
    :wave::Welcome::Handshake
    being it's a '76 you could have the 250.
    if this is true then you can run your trans. behind a stock 302. JMO
    ...:party3:...
  3. Mavman72
    302 will drop in with the addition of V-8 frame mounts.
  4. scooper77515
    That 250 puts out some pretty good power.
    Post your vin number up here and I bet someone can figure it out for you. I would guess that the vin number contains the engine size.
    Or, post a picture and let someone see what it is. Someone will know just by looking.
    I have a 302 so will not be able to help here.
  5. jaycee21
    jaycee21 Member
    Houston
    Maverick
    My VIN is 6K92L184368
  6. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    welcome aboard
  7. rayzorsharp
    Definitely is the 250 engine. The L is your engine code. And yes, you can keep the same tranny if you go up to the 302 engine.
    T - 6-200 - 1 bbl - 78-81 Horsepower
    L - 6-250 - 1 bbl - 78-90 Horsepower
    F - 8-302 - 2 bbl - 143 Horsepower
  8. PaulS
    To answer your questions; the next size up is a 302. it is a factory bolt-in job with all the related parts. With a moderate build you can get 300 - 350 HP out of it. The C4 transmission will bolt right up to the 302 but if you build the engine you will have to make some mods to the C4 in order for it to handle that extra HP. At least 5 clutches in the direct drum and a good kit (TransGo 40-2) in the valve body. I would direct you to the "Tech Articles" forum and the "How to Hot Rod Your C4 Automatic" thread. It contains a do-it-yourself list of mods. You can always Email me for help with it.
