High $$$, high-back buckets
Discussion in 'General Maverick/Comet' started by fixmer, Mar 28, 2004.
  1. fixmer
    fixmer Member
    I am wondering if anyone has had experience getting original-style seat covers custom made. I found a company that will make them from "original materials". http://www.autoupholsterykit.com/ They seem to do nice work from what can be seen on their website. The price to do all the seats will be about $1000. AutoKrafters has seat foam for the front seats for about $130 per seat. I am about to put almost as much money into the seats as I have in the whole car! I definitely want to keep the original look...no velour, or anything like that. Any thoughts, experiences, referrals, or recommendations would be greatly appreciated.
  2. John A Fasig
    John A Fasig Member
    over here now
    several plastic and tin
    I don't think those seats are original in the maverick. mabye you already no that, If so im sorry. Wish you were closer to Pa. I would trade ya for some maverick buckets. I'm looking for that kind. John
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Those look like Grabber buckets. I also like those blacked out deluxe door panels. I would think a local upholstery shop could do a pretty decent job for $600 ... I had one bucket done on a 73 style bucket and it was $165 ...
    Also - I don't see it on their website but pretty sure these guys make Maverick foam for alot cheaper
    http://www.mustangmarket.com/foam.htm
  4. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Well the good news is the buckets in your car are the highly sought after ones. They are original. The bad news is, upholstery work is expensive. I do a bit of my own and also have a local guy do the hard stuff. It aint cheap. Check around your area, go into a fabric store and ask for info on upholsterers. You just might luck out and find someone who moonlights with it. Good Luck!
    Dan
  5. John A Fasig
    John A Fasig Member
    over here now
    Well what are they besides well sought after? maverick or mach 1.? I'm going with my original post and staying with THEY ARE NOT ORIGANAL. Is the dumb truck driver right? John
  6. Dan Starnes
    West Central IL
    Yes, they are original for the Maverick. Craig Selvey's yellow car had a set. Guess we just dont see enough of them around anymore. Seems like most mav/comets came with bench seats. I will guess on this one but I think they were available from 71-74 on Mav/Comets. My 70 Cyclone Spoiler has a set too. Ford used them in several cars.
    Dan
  7. Dan Starnes
    West Central IL
    Here is a pic of Craig's former car.
  8. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Those are the same seats that I have in my car. They were available in '71-'73 Mavericks AND Mustangs. Although not as comfortable and supportive as modern seats, they look very good and fit just right in '71-'74 Mavericks and Comets...
  9. John A Fasig
    John A Fasig Member
    over here now
    I still beleive that those are mach 1 and rustange, and the maverick and pinto were the same witch are not quite that high like 6-7 inches shorter and about 2-3 inches wider at top......
  10. 69maverick
    69maverick Member
    connecticut
    69.5 maverick
    There are the right seats of for that year car! I have a set of them in my car. I used 1970 Mach 1 deluxe covers on mine they fit perfect.
  11. fixmer
    fixmer Member
    If the Mustang covers would fit I would like to use them. I could save a bunch of money and have something that looks decent. Only bad thing is the existing covers on the back seat wouldn't match. The Mustang rear bench has got to be different, doesn't it? Believe it or not (from the photo), the back seat is in almost perfect shape except for one short split on a seam that I might be able to have repaired. Thanks for all the thoughts and ideas.
  12. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Well, I believe that there are Mustang ones that are the same pattern as the ones you have on the Maverick buckets right now. So just find that set of seat covers, and you'll be set. :)
    -Corbin
  13. Dan Starnes
    West Central IL
    yeah I think the 71 pattern off a stang would be the same. The pair I have in my cyclone are the same material, but the seams in the center run parallel with me as I sit. If you snoop around at mustang supply houses try and look 70-71 samples to see if the same.
    Dan
  14. 69maverick
    69maverick Member
    connecticut
    69.5 maverick
    The mustang covers don't have the Emblem on the back of the seat in the middle but it fits on the frame. It was pretty easy to do. Just make sure you have a good Hog ring tool. As far as the back seat I don't think a 70 seat cover will fit? It has a larger hump in the center of it than a Mav. I have a pic of one of my seats covered. I will post it after I put it on my site.
  15. 69maverick
    69maverick Member
    connecticut
    69.5 maverick
    here is one.
