High Strength Drive Shaft
Discussion in 'Technical' started by MikeG747, Jun 9, 2009.
  1. MikeG747
    MikeG747 Member
    Arkansas
    Is there any place that custom makes High Strength Drive Shafts? I need one that will handle some horsepower. :chirp: What has everyone else done? Let me know.
    Thanks, (y)
  2. brainsboy
    brainsboy Member
    Tampa
    unless your pushing 1000+ horse power your drive shaft will be fine. The weakest link is in your universals anyhow.
  3. Bryant
    mark williams, inland empire drive line.
  4. 70mavrik
    70mavrik Member
    SoCal
    i'm using the drive shaft out of my brothers 93' mustang works just fine. How much power are you planning on putting down?
  5. rthomas771
    I had one made from a local shop that build dirt cars. They use thicker wall tubes.
    I seen typical big block street cars twist factory driveshafts
  6. MikeG747
    MikeG747 Member
    Arkansas
    Thanks for the input. :Handshake I will be calling them. Here is the link to there site if anyone else is interested.
    http://www.iedls.com/driveshafts.html
  7. MikeG747
    MikeG747 Member
    Arkansas
    My goal is 500. Not sure how close I will get. As soon as it is all together I will be headed to the Dyno for tuning. I will keep you posted. (y)
  8. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Stock with spicer joints.
