Hit a snag - starter
Discussion in 'Drag Racing' started by mcknight77, Mar 29, 2016.
  1. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    This morning it looked like I would be able to make the opener on Sunday. This afternoon, not so much. Went to fire it and no starter engagement.
    I have a small gear reduction starter in it that lists for mid '90s trucks and Broncos. It's a two bolt 10 tooth starter. I need the small starter for header clearance and for a internal solenoid. I don't want to mount an external solenoid on the inner fender panel.
    The problem is the C-4 is the original '74 Mav and the 5.0 is an '86. So, I can't just look up a starter in the parts book.
    Anyone have any recommendations?
    Jim
  2. Krazy Comet
    There are PMGR starters that work, I have one on my Comet that has '91 5.0 & orig C4... I bought mine from ebay for the 157T C4, it determines what starter fits, not the engine...
  3. junrai
    junrai Member
    rancho cordova ca
  4. mcknight77
    mcknight77 Member
    Boise, ID
    Good info, guys. Thanks. I'll see if I can figure this out today.
    If I can get the starter fixed all I have left is to install the Caltracks, weigh the car and get it aligned.
  5. mcknight77
    mcknight77 Member
    Boise, ID
  6. Krazy Comet
    What starter did you have??
  7. mcknight77
    mcknight77 Member
    Boise, ID
    The starter fit mid '90s Broncos and pickups. The part number from O'Reiley was 5310. The one that worked was a 5308 for a '95 Mustang 5.0.
