holley carb flooding
Discussion in 'Technical' started by wolfheads, Dec 6, 2015.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    I installed a suppose to be new Holley 600 carb on my 302, but it started running rough and not idling. When I shut it off, I looked in the carb and noticed the back 2 barrels were dripping fuel into the intake which would cause it to flood out. I don't think anything else would cause it to do this except the carb. I'm going to re-install the motorcraft 2 bbl and see if that cures it. It sounds as if the Holley may have some trash in it but everything is new including the tank, fuel pump, carb and intake as well as the fuel lines. There should be no trash in the system.
  2. Krazy Comet
    Should be, and what happens in real world are often different things...
    Most Holleys have a sight plug in the passenger side of the bowls that fuel level can be checked... It's fairly easy to pull a bowl(especially rear), and check for dirt in the needle valve...
    Static likes this.
  3. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    My Holley, new out of the box, had the fuel level way out of adjustment.
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    If the float level is set to high. This will happen. Even on a new carb it will need minor adjustments.
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Don't put the 2-barrel back on. Adjust your floats, make sure the needle & seat is clean, and make sure the secondary throttle blades are closed at idle.
  6. wolfheads
    wolfheads MadMav
    Florida
    I think I found the culprit. Trash in the carb. I replaced everything fuel related prior to the new carb EXCEPT the metal fuel line from tank to fuel pump. Must have a lot of trash in the old lines. Will need to replace or blow/clean them out.
  7. mojo
    Even w/ trash in the old lines the fuel filter should have kept the trash from entering the carb. You do have one (fuel filter) , right?
    baddad457 likes this.
  8. wolfheads
    wolfheads MadMav
    Florida
    The only filter the car had at the time of the new carb install was one on the line right by the tank. There was not one between the pump and the carb. There is now.
  9. wolfheads
    wolfheads MadMav
    Florida
    There is for sure trash in the new carb as seen in the pic.
  10. groberts101
    groberts101 Member
    Minneapolis, MN
    Glad you got it all sorted out. I'd recommend another inline filter right before the carb. Only takes one little spec in between the needle and the seat.
  11. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    Do you still have the sintered bronze filter in the float bowls? If you did, that trash would not be there. In your application, that bronze filter will make NO difference in performance contrary to popular belief.
  12. wolfheads
    wolfheads MadMav
    Florida
    I had the carb cleaned at a shop and installed a filter by the carb. It works perfect now.
    Crazy Larry likes this.
  13. kzm0st
    kzm0st Member
    1967 mustang 1983 v8 ranger
    Had same problem with my 1984 302 ho motor.New fuel tank and filter in line at carb.Needle and seat gushing out vent tubes and more then once replaced.I used summit copy of ford carb run perfect high cam and electric choke.
  14. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    you can beat the price of the Summit brand of the Holley Carb wet flow tested bolt on and go all the features of the Holley carb half the price and they run great
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I've never tried one but I've always thought they were cool.
