holley needle and seat oring
Discussion in 'Technical' started by safado, Feb 3, 2012.
  1. safado
    safado Member
    West Phoenix, AZ
    Has anyone found a cheap replacement for the oring that goes around the holley needle and seat assembly?? i know you can buy the 34-7 kit.. but was looking for a ACE/lowes/homedepot option..
  2. bmcdaniel
    Don't cheap out on something that keeps fuel from spraying all over your hot engine...
    Stuff you find at a home improvement store probably isn't fuel resistant.
  3. safado
    safado Member
    West Phoenix, AZ
    I figured there be someone looking out... maybe they sell viton orings.. have you ever checked? or just shell out the cash to holley for new ones?? no problem either way... what ever works for you..
    :) I just wanted be clear that not I'm snapping or being a douche... I hangout some pretty nasty forums, and apologize for being brute... I mean nothing bad.. Just looking or a alternative than giving holley more of my money.. I do appreciate the advise..:)
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Jegs 555-150249 $3.99
  5. baddad457
    You can buy new needle /seats at the local O'Reilly's, Autozone, Advance, Kragens, etc. When you install it into the bowl, lube the o ring with brake fluid before you screw it in to avoid tearing the rubber. Ditto for the fuel transfer tube on single feed Holleys.
  6. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    Try a garage or lawn mower shop with a box of differant size o rings.
    You might get lucky and find one for fuel.
  7. safado
    safado Member
    West Phoenix, AZ
    I think the point was not communicated.. I wasn't looking to buy the 34-7 holley kit that sells the o ring nor the kit that sells the needle and seat.. I wanted to see if any other cheapskate, like me, had ever used or found a equal o-ring for say 10 cents, instead of paying 4-15 dollars for one.... I know there are many ****ty o rings.. I tried a nitril (sp?) from harbor freight and to my surprise (sarcasm) it was junk.. tore, tried another one split..left it submerged in gasoline overnight.. disappeared..etc..
  8. bmcdaniel
    You've probably wasted more time, effort and money than if you would have bought the correct part to start with.
  9. safado
    safado Member
    West Phoenix, AZ
    you miss the point... thanks for your input though..:tiphat:
  10. baddad457
    The reason they tore and/or split was you likely didn't lubricate the ring before jamming it into a dry hole. USE BRAKE FLUID.
  11. safado
    safado Member
    West Phoenix, AZ
    they were lubed with wd.. I think they were just old.. cause, you could grab them between your thumb and index and just roll them around and they would fall apart.. I don't know how old they are.. my neighbor brought them over.. he said he got them from work.. the parts box had about an inch of dust.. needless to say they are in the trash..
  12. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    O-ring cheapscape
    I'LL send you a couple. A stamp cost more need address here pm me NO Bull Sh---Y O RINGS Allowed.
  13. safado
    safado Member
    West Phoenix, AZ
    Wrighttime, I thank you sir for your offer.. I really do appreciate it...
    The whole point of this thread was just to see if anyone had walked into ACE/Lowes/Home Depot or any of the like and found a o ring that worked on a needle and seat assembly.. that is all..
    I know this is petty, but i just figured there would be somebody as cheap as me... I guess not, or at least they haven't had the urge.. I do collect the aluminum cans and water bottles that are drunk here at the house and i buy the toilet paper from bulk at costco, but i don't split the sheets (costco TP is 2ply).. and I courtesy flush (even at home).. and when i'm at costco I always get the hotdog and soda (pop for the East guys)..
  14. bmcdaniel
    You're right! What is the point? LOL
  15. safado
    safado Member
    West Phoenix, AZ
    I can see now how you got your post count so high....
    please refer to posts #1 or #13, for the point.. if you still don't get it.. I don't know what to tell you..
    one good thing out of this.. say the moon was aligned with jupiter or whatever.. and one day someone with a holley has a overflow day.. and they remember the help/advise bmcdaniel gave to the cheapskate guy on the forum, that in a pinch he can find a ACE/LOWES/homedepot and find a good oring that would work with no issues.. since summit isn't around the corner nor is the local autozone/orielys etc.. maybe, that can be the only good out of this thread.. well, besides the post count climbing..
