I put on a grabber hood an can't seem to get one back corner up and even. I've messed with it for a couple of hours. I replaced all hood and radiator stops and it's better but still not right can anyone give me some tips?
did you try adjusting the 3 bolts on the fender apron that the hinge mounts to ... you can get to them from the inside of the fender
I never could get mine to sit level on one side either. With the hinge adjusted all the way up, it was still too low. I used a 1/8" shim between the hinge and the hood to level mine....
Yep tried adjusting the three bolts but still not quite level. Shims is a great idea which I will try.
You need to move the hinges DOWN in order to get the hood to move up. I know it doesn't sound right...but it is.
Thanks Craig I will give it a whirl. One side is great it's the other side that is giving me problems.
