Hood Hinges
Discussion in 'General Maverick/Comet' started by gsjohnson, Mar 15, 2003.
  1. gsjohnson
    gsjohnson Member
    Pasadena, California
    72 Maverick 5.0 EFI
    Does anybody have any alternatives to the hood prop rod? I hate that SOB. Anyone know of any hood hinges with springs that are a direct bolt in? Early Mustang maybe? Ideas welcome...
  2. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    I have been thinking about the same thing, one idea I was thinking about, but I have not explored is those hydraulic??? type of hood props that they have on later model cars. Anybody try this yet?
  3. Mike Gee
    Mike Gee Member
    Vancouver BC Canada
    1974 Maverick 4dr 250 IL6
    Gas Struts
    My neighbour installs replacement struts for trunks and hoods. He's installed gas struts for new cars such as PT Cruisers and Lexus and older models such as Covettes for example.
    Contact Frank Irvine at info@strutwise.com or visit his website at www.strutwise.com
    He's now designing two struts for my 74, and will be able to get a custom set of struts for your Mav.
  4. Maverick Guy
    NE Ohio
    That's it!
    I couldn't think of what they were called. When you get them, maybe you could post a picture of them. I am sure others would be interested as well.
    Thanks for the info!
  5. Mike Gee
    Mike Gee Member
    Vancouver BC Canada
    Maverick Gas Struts
    Yes, I'll get some jpg's of the struts and installation points for you and others to view.
    They'll probably be posted on the www.strutwise.com site sometime next week.
  6. Mike Gee
    Mike Gee Member
    Vancouver BC Canada
    Gas Struts cont'd
    We are still matching up the proper combination of bracket and struts to fit. We'll have it all together soon. The struts should fit in any 6 or 8 cyl engine bay.
  7. gsjohnson
    gsjohnson Member
    72 Maverick 5.0 EFI
    I'm looking forward to seeing the results. Any idea on the cost?
  8. Thack
    Thack vision advicator
    Moreno Valley Ca
    I'm very intrested in what you guys come up with, I tried to make a set on the new car but I was having problems with the way the hood closes. As you guy probly know it doesn't close in a linear fashion,when I did get it to work the hood wouldn't open more than before. My goal was to have the hood open more than the prop rod so I would stop banging my head on the hood latch. The other problem I had was the under hood frame flexed alot. I figured if I changed to pinto/mustang II hinges that would have cured most of the problems but, I really didn't want to go that rout.
    I did have it easier than most because we have the mustang II front and I didn't have to contend with the shock towers.
  9. jeremy
    jeremy I build t5's
    Corona, Ca
    whats up thomas---don't you already have a notch cut out in your skull from that hood latch?? Why make the hood go up further-that would ruin the fun of working on a Maverick.
    I just love to start cussing and screaming before I even pick up a wrench.
  10. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Well, we heard alot about the use of struts and gas shocks, but what about the early model mustang hinges with the heavy springs. Has anyone tried them?
  11. Mavaholic
    I looked at the early Mustangs. Dont even look close. Another problem is the underside bracing on the Maverick hood. Its not all that much and too strong a spring will probably end up bending your hood.
  12. gsjohnson
    gsjohnson Member
    72 Maverick 5.0 EFI
    I've tried 65/66 Mustang hood hinges & there isn't one(well you can line up one) hole the lines up on the body & the hood. I've also tried 67 thru 70 Mustang hinges(they are all the same) with the same results. Next I'm going to measure the hood hhinges off of my Torino, but I expect the same results. If we find the right hood hinge we can always interchange the springs for the right tension. Additionally, Branda sells the lightweight springs for fiberglass Shelby hoods.
  13. Maverick Guy
    NE Ohio
    Mike
    Just curious how you made out with the gas strut project?
  14. Mike Gee
    Mike Gee Member
    Vancouver BC Canada
    Gas Struts
    Dave,
    We were able to get one side done (battery side), but we couldn't use the same strut for the other side. The one strut was able to hold up the hood. For safety sake though one strut wasn't enough, so Frank has gone into his search mode to find the right combination. It looks as though we need a longer shaft and shorter strut body to make the clearance, and that means checking a few hundred existing struts to find the perfect size. I thought we would have got that done by now, but it's not that easy, Frank says.
    :( More news soon.
  15. 19FordMav72
    19FordMav72 Guest
    Would the hinges from a hatchback work at all? Maybe a minivan or suv?
    I really hate those prop rods. They make me nervous around my grills that I had just finished. Let me know when you find the gas shocks that work, and please post some pictures!!:cool: :D
