Houston we have a Wheel/tire clearance problem
Discussion in 'Technical' started by justin has a 74, Feb 5, 2011.
  1. justin has a 74
    kentucky
    Well i just put on my new keystone wheels and noticed i have literally 1 mm of clearance between the tire and traction bars.... no big deal, ill just keep them off the car. Well the leaf springs are also 1 mm away from the tires. Anyone see a problem with this?
    :hmmm:
  2. Dave B
    It won't be a problem, unless you drive the car....
  3. justin has a 74
    kentucky
    Yeah, i plan on letting it sit for a couple years:D
  4. rthomas771
    How far is that in inches? They didn't teach the metric system when I was in school
  5. Dave B
    1 millimeter = 0.0393700787 inches
  6. rthomas771
    If my math is right...that is just over 1/16"...less than 5/64"...less than thickness of 3 quarters stacked on top of each other.
  7. justin has a 74
    kentucky
    What?:huh:
    Is this a yes or a no?
  8. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    You'll definitely want to put the white lettering on the outside:rofl2:
    What is the rim width and back spacing and the tire size? Maybe a spacer can get you straight.
  9. bmcdaniel
    That's why they make wheel spacers.
  10. bmcdaniel
    Your math is wrong...
  11. rthomas771
    You're answering a question with a question. I asked you How far is one mm in inches? Is it between 1/16"-5/64"? If the answer is yes...then it is not enough room and the tire will rub.
  12. FishnRace
    FishnRace Jamie
    '72 2dr 351
    1mm is just under 1/25" ... it's practically touching at rest ... it ain't gonna work like that:naughty:
  13. justin has a 74
    kentucky
    Ok a 1/4 of an inch is more realistic.
  14. yellow75
    Tillamook Oregon
    You already know the answer to your question :huh:, you didn't tell us if you have any clearance on the fenderwells if so then just get some spacers like suggested
    Since Frankee's not around much anymore we have to pick on you now j/k
  15. justin has a 74
    kentucky
    Well, i was worried:hide:
    Dont want my tire popping going down the freeway at 50 mph
