How can I make the 302 motor faster in my '71 Comet?
Discussion in 'Technical' started by lika, Nov 27, 2008.
  1. lika
    lika Señor Comet
    IA
    comet 71
    I have a 1971 Comet. I'm working on rebuilding the body. I'd also like to make the motor faster if possible. It is the regular 302 motor, automatic. Does anyone have any tips?:drive:
    Thank you for the help!
  2. newtoford
    newtoford Member
    New Castle Delaware
    headers, cam, intake , carb, gear swap, shift kit (automatic)
    all depends on how much money you have
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    without going into the motor, you can add power in many ways.
    1) headers
    2) intake
    3) carb
    4) gears
    5) converter
    6) remove water pump belt by converting to electric. This can get expensive for a good electric pump or you can buy one of these http://store.summitracing.com/partdetail.asp?part=MOR-63750&autoview=sku which I have used and it did a decent job.
    7) ignition upgrade (MSD is my preference)
    *the above listed has more $$$ involved, but all bang 4 the buck.
    *below is some out of the box, cheaper but less bang.
    8) advance the timing a couple degree's
    9) index spark plugs
    10) cooler thermostat
    11) lose some weight
    12) front end alignment
    13) good set of plugs and wires
  4. Mavman72
    The bes initial mods would be...in this order:
    Better rear gears... say 3:55's
    Dual exhaust/headers
    4 bbl carb and aluminum intake
    These simple mods will wake the car up and make it fun to drive...
    After that... then you can put a cam in it to work with your combination.
    Once you get to the point of putting a bigger cam in it you are officially hooked and will begin spending every spare penny on it you can... you poor guy...its soo much fun!! Enjoy!!!
  5. bmcdaniel
    Yep, then comes the nitrous and the stroker kit, not necessarily in that order.
  6. Bryant
    all good recomendations. i would do gears, and a converter. those two will give real kick in the pants that you will feel. then do the exhast. the sound will help give a sence of power and it will free up some power. then do a carb and intake and if you can at the same time do a cam.
  7. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    I did a cam, ported 351 big valve heads, exhaust, intake and 4 bbl carb on the stock 72 302 with 3.70s and a 9" rear, and a 5-speed. It was so much quicker it didn't seem like it was the same car. I'd say consevativly it gained 100 HP. It makes all those nice muscle car sounds and flat gets it on when I nail it. Still pulls 16 MPG on the highway. I think it would improve if I switched to a vac secondary carb instead of the 650 DP. Switching to a 5-Speed is a good idea since you already run a standard. Use a junkyard 87-93 5.0 Mustang driveline with adaptor u joints... Good times.
    P.S. uuunnnless you don't mean stick shift when you said standard. Then an AOD would be a good idea.
  8. baddad457
    Here's a few low buck tricks: ditch the points in the distributor for an electroinc module, matching hotter coil, then advance the timing to around 12* BTDC. Replace the Autolite 2 bbl with a Holley 500 2 bbl. Get a set of headers and dual exhaust. If you really want more, replace the rearend gears with 3.50-3.70's.
  9. lika
    lika Señor Comet
    IA
    comet 71
    Thank you
    Thank you all for the advice.
    Here is a picture of my motor 302
    that i want to make better.
  10. courier11sec
    courier11sec Member
    Tucson, AZ
    John was all over that one. Only the thing I have to add to that is make certain when you have the throttle pedal to the floor you are actually at full throttle. You'd be shocked at how many vehicles are on the road that can't be taken to full throttle.
  11. newtoford
    newtoford Member
    New Castle Delaware
    good scrub wouldnt hurt :bouncy:
  12. 70ProStreet
    70ProStreet Member
    Taylor, Michigan
    If it has any emissions equipment, remove that.
  13. justin has a 74
    kentucky
    take out the air conditioning like me!, im assuming it ways a woppen 5 pounds
  14. bmcdaniel
    Something's not right there. The combination in my signature gets 23 mpg highway doing 70 mph.
  15. justin has a 74
    kentucky
    your rite....i get 18
