How do I do a controlled burnout?
Discussion in 'General Maverick/Comet' started by mashori, Dec 23, 2009.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I've never done one so what's the process? :drive:
  2. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    well i dont know what others do but i give it about half brakes and full throttle :whistle:
  3. scooper77515
    The rear brakes are not as firm as the front brakes, so if you mash the brakes and nail the gas, the rear tires will start to spin before the front brakes let you move.
    It works better if you install a line lock which is an electric solenoid mounted in the front brake line between the master cylinder and the front brakes. Mash the brakes, hold the button, and let off the brakes. Now the front brakes still have full pressure on them because the line is blocked by the line lock, but the rear brakes are fully released. Mash the gas and go through as many gears as you want and whatever rpms you want. Let off the button and the car will start to move.
    The line lock is the silver thing at the left side of the picture, mounted to the shock tower.
  4. drag460
    drag460 T-Shirt guy
    El Paso, TX
    Brakes and gas!
    Here's what not to do...
  5. Dave B
    "That was not the tires" :rofl2::rofl2::rofl2::rofl2::rofl2: You'd think one of the guys watching would have said something before it went on to long..
  6. 1973Maverick357
    Cookeville TN
    I think this is a good example of what not to do also.
  7. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    POWERBRAKE!!!!!
  8. darren
    WARNING BAD LANGUAGE> MUTE if you have little ones.
  9. chirt
    chirt Carlos Hirt
    Massachusetts
    I guess he forgot to shut the traction control off :rofl:
  10. 1973Maverick357
    Cookeville TN
    It pauses the video for like 10 seconds and says Swearing in the video.
  11. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    pay close attention to your rear tires in the mirror to make sure they are spinning or you will be spending a lot of money on new parts
    here is a good video
    brad:)
  12. PAINTANK
    1973 Comet 2 dr
    He needs worse brakes.
  13. scooper77515
    What happened to that camaro? That could have been REALLY bad.
    I don't know what is wrong with these guys. You can hear the tires screeching when doing a burnout. If I didn't hear my tires break loose, I would stop revving it.
    That and most times, the rear end swims side to side a little while the tires are spinning.
    Burnouts are more than just smoke and noise, there are all kinds of tactile sensations that let you know when it is all going the way it is supposed to. So none of these "idiot" videos should ever have occurred if they guys behind the wheel were paying more attention to their car and the burnout and less to the video camera.
  14. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    A little water helps. My car won't break loose and spin on dry pavement, but with a damp surface, it does fine.
  15. 71gold
