How do I mount a Grabber Spoiler???
Discussion in 'General Maverick/Comet' started by MaverickRunner, Apr 24, 2004.
  1. MaverickRunner
    MaverickRunner Member
    North Port Florida
    73 Maverick 302
    Ok I got a Grabber spoiler...I got the end pieces on, but how do I line up the fin on the deck lid? I know I need to drill holes in the deck lid...is it at the body fold, or under it??
    thanks for the help
    Todd
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Craaaaig, he needs your template (or jig, or whatever you call it)! :)
  3. Craig Selvey
    Yes....I have a "jig" that can be used to mark where the holes go. FREE to use...you pay shipping there and back.
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Measure the spacing of the studs on the spoiler, mark the trunk lid, and use a hole-saw...
  5. John A Fasig
    John A Fasig Member
    over here now
    several plastic and tin
    Drill at a 45 degree angle right at the back of the trunk. YOU don't need no templet,that would be like reading instructions.
    just do like T.L. said. All I can add to that is to use a big nail as a center punch because the part you need to drill is VERY,VERY, not flat. you can dew it!!!!!!!!!!!
  6. Mavaholic
    1" hole saw
  7. 71gold
    it"s only a "thang". the spoiler will cover the whole hole, so it dosen't have to be exact. it took me for "ever". i spent a day making my holes perfectly square like the ones on the lid i got the pattern from. just don't loose the funky little clips that mount the spoiler....j.m.o....frank...:bananaman :bananaman
  8. Craig Selvey
    If the holes were SQUARE...then they weren't factory holes.
  9. squeal1
    squeal1 Out To Have Fun
    Evansville, IN
    72 Maverick Semi Mod, 75 Project
    Hey Tod I got a grabber deck lid here at the house. Let me know if I can help man
  10. MaverickRunner
    North Port Florida
    73 Maverick 302
    Ok Craig I need the jig....lol How much do I need to send you for shipping. OH YEA what mounting clips....I dont have any.....Craig do you have some for sale...????
    Or Neal want to trade...lol
  11. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Todd, you can do this, If I can anyone can. The mounting brackets you are missing are a pain. I did not use mine. I cut conduit into about 1.5" sections. Then drilled a hole thru each. The bolt for the spoiler goes thru and you nut the end. Now how to drill holes for spoiler flying blind.
    1. Set the spoiler at the edge of the deck lid where it curves downward, and I mean right on the curve.
    2. Mark the spots where the bolts are.
    3. Drill using a drill bit about the size of the bolts, smaller to start is easier in the end.
    4. When you have drilled the holes and you can put the bolts thru, it starts to give you an idea of how it is going to lay. Start checking yourself for some accuracy. Does not need to be perfect, You will have room to adjust.
    5. Using a 1" hole saw, start drilling, remember all is happening right on the curved portion. It can be kind of hard to drill, but take your time.
    6. After you have the 1" holes drilled, you can test fit, you might have to file around the sheet metal to get it to fit good. I abused a drill bit to do this, faster.
    7. Should be down on the decklid now, check your end clearance. Should be perfect at each end, a little tolerance is great to have for adjustment.
    8. Cut some 1" plastic conduit like I stated earlier. Makes for great mounting brackets and they actually hold on the studs so you are not fumbling so much. There is not much room in there for your hand.
    9. When all is fastened, drink cold beer and congratulate yourself.
    :clap:
    Dan
  12. Craig Selvey
  13. mavman427
    mavman427 has entered the building.
    SLOtown, CA
    1971 Mav with all the trimmings....302 Auto, Custom buckets, Power Brakes, A/C, PS, Grabber hood, spoiler, and mirrors.
    Take some careful measurements and use a hole saw. Like someone said, the angle is roughly 45 degrees from the trunk lid and you drill right on the edge of the trunk lip. I think I used a 3/4" hole saw and then just used a die grinder to expand the holes a little. It worked out well because I took careful measurements and centerpunched the trunk lid, made it pretty easy.
  14. MaverickRunner
    North Port Florida
    73 Maverick 302
    Its on guys..but not fastened down. Will have to get some pipe to do what Dan said.
    Thanks guys for the help
    and thank you ward......lol
    Todd
  15. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    No problem Todd, post a pic when you get a chance.
