How do you drain the rear end oil?
Discussion in 'Technical' started by Bob Wiken, Feb 24, 2008.
  1. Bob Wiken
    Fayetteville, Arkansas
    I was all set to change the oil but I don't find a plug on the lower part of the dif at all. Do I unbolt the whole thing? I don't want a bunch of springs, shims, and snakes jumping out at me becausei don't knnow whatI'm doing.
    Thanks
    Bob___
  2. Mavaholic
    You have to pull the axles, drive shaft, and then the center section. Nothing will fall out.
  3. Bob Wiken
    After a 10 minute look on a creeper with a flashlight, scraper and wire brush, I can't find a drain and the only place on top to put oil in loos like the breather tube and i pretty sure that's not the place. HELP!!!
  4. Bob Wiken
    you have to do all that just to chance the oil?
  5. 71gold
    ...a good time to install a ...drain plug...:Handshake
    ...Frank...:bouncy:
  6. don graham
    Like Dennis said. Only thing iI would add is to make sure you have something to catch the rear end fluid. Don't want it on the floor if you can help it. It stinks and is pretty thick (90 weight).:)
  7. Bob Wiken
    There appears to be no filler hole either. What am I not seeing
  8. krelboyne
    krelboyne Remember
    Salem, Oregon
    Welcome to Ford engineering. :clap:
    I think that the dealers used a siphon type machine to remove gear oil out the fill plug.
    The way I drain the oil, and it only gets most of the oil out, not all.
    Raise the rear end up to the highest point on a pair of jack stands.
    Remove one axle, and lower that end of the axle down with your floor jack.
    This will drain most of the oil out of the sump portion of the rear end housing.
    You can loosen the third member, but as mentioned it gets messy. The other problem is that it is liable to leak after reinstallation.
  9. krelboyne
    krelboyne Remember
    Salem, Oregon
    It is a bung type plug.
    Look for a square hole in a flush mounted round plug. It will be in the cast iron third member, this is also your fill level.
    You will use the end of a 3/8 inch ratchet extension to remove.
  10. Bob Wiken
    OK thanks. I'm off to wire brush some more.
  11. don graham
    The filler holle is not on top. It should be on the rear of the housing. Mine comes out with a 3/8 ratchet with no socket on it. You only want to fill it up to the hole.:)
  12. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    NAPA should have or be able to order a Rhodes gun for you......a suction tool that allows me to do this at this very thing. The fill-plug is located on the drive shaft side of the carrier/housing,on the driver side, about at the same level as the drive shaft.....Hope this helps:thumbs2:
  13. Bob Wiken
    thanks I know the place there appears to be a Plug over the Bung.
  14. Craig Selvey
    Why are you changing the oil?
  15. 71gold
    ..take and put an extra nut on one of the bottom studs on the housing and use it as a ...jacking nut... to remove the stud....take the filler plug out so it can breath...(learned this on the...MMB...) :huh:
    ...Frank...:Handshake
