How do you run a single fan belt?
Discussion in 'Technical' started by scooper77515, Nov 2, 2006.
  1. scooper77515
    I currently have power steering sharing one belt with the water pump, then alternator on it's own belt.
    I am converting to manual steering, and will lose that belt.
    How do I get the water pump to turn with the alternator as the "adjuster"?
    I assume I need a different water pump pulley? If so, part numbers? Or can I just go to Autozone and ask for a water pump pulley (or full pump) from a manual car?
    I have no problem buying an aftermarket hi-performance water pump while I am at it... :rolleyes: It could never hurt with the heat we have down here. Again, if that is a recommendation, part numbers, etc...
  2. Jamie Miles
    My best guess is you need to get a water pump pulley from a non power steering car. Do you have any pics of how the belts are currently routed? Sounds like a good time to go to a serpentine belt to me...
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Like Jamie said .. you will need the pulleys for a no-PS and I assume no-Air car so they will be single groove.... you can buy aftermarket pullleys from auto parts stores ... I used a March set to do exactly what you are doing .... I didn't have the time to fool around with getting the correct factory pulley's ...
  4. Rando76
    Rando76 Member
    Claremore, OK
    I did the same thing with my '73, but luckily already had the pulley.
  5. Rocco
    Rocco Member
    Chicago, IL
    1977 Maverick
    An electric water pump is an option you could look into since you are concidering upgrading it anyway. Then the belts are a non-issue. Plus you free up a few ponies!
  6. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    is your crank pulley 3 bolt or 4 bolt
  7. scooper77515
    4 bolt crank, 3 groove pulley. Used to have AC, soon-to-used to have PS.
  8. NAFORD302
    NAFORD302 Member
    SILEX MO
    i will see if i have any thing for pulleys on lunch i will try to find a rotor for that cap
  9. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Good luck finding any stock pulleys... I never did. I ran my alternator farther back for a while, but it's not a good setup long term. I'm ready to give up and just buy the March pulleys for single belt setup.
  10. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    This is how i did it,i used every thing from a 5.0 mustang and just made a couple of new spacers up.
  11. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    If you intend to use stock pulleys, then the single lower and matching WP pulley is the set you need.
    There were MANY made on MANY different Fords, but everyone I know grabs them up when they find them, so they can be scarce unless you are the first person to come upon a set.
  12. wagesofsin
    wagesofsin Official Lurkologist
    sarasota, florida
    74 challenger , 73 'cuda , 72 challenger , 74 barracuda
    all you need to do is unbolt your alternator, move it to the other side of the engine bay. i used the same bracket for the alternator,just flipped it over. some very minimal grinding was necessary to clear the valve cover, but its a gravy fit. i had to bend the original p/steering lower adjustment bracket to fit.if i can get my crappy digital camera working ill snap a few photos, but all in all its really easy, and free.:drink:
  13. scooper77515
    wages,
    Please, pictures would be greatly appreciated. I never thought of (something as simple as...) moving the alternator :slap:
    As long as I have room for my centrifugal blower later on, I don't care what is under the hood :bananaman
  14. wagesofsin
    sarasota, florida
    ill do what i can, but really, if ya have time, just unbolt the alternator. hold it on the other side...it fits perfect. use the already there p/s lower banana bracket. just flip the alternator mount over. youll see its gravy. ill try and get some picks. youll need a new belt, of course, and to rewire the alternator leads so they reach. belt number is 11av1105...its a goodyear belt.:drink:
  15. scooper77515
    THanks wages. I will look at that this weekend.
