How do you tell if you have v8 springs or v6 springs?
Discussion in 'General Maverick/Comet' started by ford71, Jan 18, 2015.
  1. ford71
    ford71 Member
    Spokane Washington
    1971 Ford Maverick
  2. Krazy Comet
    For the originals, 6cyl coil size is slightly smaller...
    I dunno on aftermarket, as the 6cyl springs I installed are same size as original V8 springs, they are 1/2 coil shorter though...
  3. Acornridgeman
    Wisconsin
    The only way is if the color code paint markings are still present. There is a chart to "decode" those. Or, if your really lucky, the factory ID tags sometimes remain.
    Here is the leaf chart - there is one for the coils too someplace.
    http://www.1bad6t.com/Maverick/repair/leafspring.html
    Mel Moeller and Paul Masson like this.
  4. rthomas771
  5. Craig Selvey
    Shoot....I wish I had seen the coil spring/paint stripe chart earlier when I did mine. I have the build sheet and went off of that.
    I have lots of build sheets. I will have to check and see how they match up with the chart.
  6. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
  7. rthomas771
    Mel Moeller likes this.
  8. Mel Moeller
    Twin Falls Idaho
  9. ford71
    ford71 Member
    Spokane Washington
    1971 Ford Maverick
    Thanks for all the information.
