how hard is it to install gauges?
Discussion in 'Technical' started by noun, Mar 18, 2009.
  1. noun
    noun Member
    San francisco, CA
    76 mav'
    hello guys!:thumbs2:
    i just bought 3 gauges:
    water temperature, oil pressure and volt.
    how complicated is it to install them? how do i proceed?
    by which hole do i pass the cable and senders?
    do I need to create a new one or can I use an existing one?
    thanks for your answers(y)
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    did they come with any instructions? I'm asking because that might be a good way to start. I found this link on the autometer site: http://www.autometer.com/download_instruction/247e.pdf
    You can get started off that and then if you hit a bump in the installation ask again. I have bought my gauges and haven't started on them yet. So I'm curious to see how it goes. Sorry I couldn't be of more help.
  3. noun
    noun Member
    San francisco, CA
    76 mav'
    yeah, came with instructions and stuff.
    i'm not really concerned about how to fix them or plug them
    it's more: were do you pass the senders and wires thru?
    I mean to go from the engine bay to the inside of the car.
    I'll tell you how it goes once i get started...
    but it won't be before few weeks:rolleyes:
  4. Dave B
    Should have bought he electric style gauges, then it's just wires that have to be passed through the firewall. The little black rubber things that hold the firewall insulating material to the fire wall are the easiest way to get wires out there without drilling new holes, just nip the end of one (about 1/8") and they are hollow, and act as a grommet, or remove one, and use that hole.
    Plus, it's no fun when one of those plastic oil pressure lines, lets go inside your car.
  5. noun
    noun Member
    San francisco, CA
    76 mav'
    What a shame.
    I should have ask before.
    that was $30 well spent. :(
  6. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    I ran my tach through a plastic plug that was in my firewall.
  7. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Agreed, thats why I run copper line.
    *your mechanical gauges will be fine.
    Just buy copper line for you oil gauge (any parts store should have it)
  8. don graham
    You most likely can find an existing hole that already has some wires in it. Should be some room in some of them. :)
  9. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    oil presure guage
    Autometer sells a steel braided pressure guage line, just put one on my car. Looks good too. But not cheap...most speed shops will have it.
  10. noun
    noun Member
    San francisco, CA
    76 mav'
    ok...
    so just to be sure where i'm going:
    here is my water temp sender, right?
    and here is my oil pressure sender, right?
    and I should be able to pass everybody through this guy, right?
    thanks guys!:thumbs2:
  11. Craig Selvey
    I don't think I would pass it thru there. That is the main wiring harness for your car.
    Look for some rubber plugs oer by your heater hoses where they go thru your firewall. If your car had factory AC...it will have the plugs.
  12. noun
    noun Member
    San francisco, CA
    76 mav'
    ok. I'll take a look on the other side of the bay when I get home.
    at least I'm right about the sensors, it's already a good step! :D
  13. noun
    noun Member
    San francisco, CA
    76 mav'
    did it yesterday...
    it took me about 5 hours (don't laugh ... it's my first time:p )
    really easy to do. (I did it, so it has to be the most simple thing to do on a car :p )
    at the end I just drilled a hole through the firewall and put a big fuel line to pass every thing through it.
    plugged everything as explained on the instruction.
    everything works great!
    happy to discover that I don't overheat even after sitting on idle in the garage for 20 minutes :dancing:
    next project on my day off: having a nice and pretty trunk:rolleyes:
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    awesome man! 5 hours well spent. Post some pics if you have any.
  15. noun
    noun Member
    San francisco, CA
    76 mav'
    here you go:tiphat:
    just be prepared for the oil sensor.
    it needs a special socket (that i didn't have, of course) to be removed.
    just went to my auto part store next door and bought it.
    I put teflon tape on every adapter and i don't have any leak for now.
    also, i used a coper line for the oil pressure (as recommended by others on this board, thanks guys!:thumbs2: )
